n6gn
- n6gn
- 4,518
- 18
W/F and SND Bad Params
Claire,
The steps I gave before seem to have fixed the problem for me. I am not an expert in this area either but no one has yet commented that there is a better way. To accomplish the block I first logged into my kiwi as root. I did this using secure shell, ssh, on a Linux host but this is also possible from a Windows machine via PuTTy or similar. Using PuTTy, simply enter the address, port 22, and it should then ask you to OK the connection. After you do, it will ask you who you want to log in as. Answer 'root'. That should get you a command line prompt from the kiwi. Once logged in I executed three lines:
iptables -I INPUT -s 47.88.219.24/24 -j DROP
iptables -I INPUT -s 184.22.160.13/24 -j DROP
iptables-save
There may be even easier ways but that's all I did and it seems to have worked, the log is no longer reporting these hits. Presumably these could start again from a different IP address and I would need to repeat one of the above first two commands with that address in place of the one shown.
Glenn n6gn -
Martin,
Thanks for documenting this. From my observations, mainly at HF, the 20-30 MHz noise that is endemic with Kiwis has a vector into the kiwi via CM noise on the LAN connection/lines. I think this is what you were addressing with the CAT5 shield, though it is still possible to get TEM ==> CM conversion on a long cable even with shielding, depending how it is configured. Current injected on the far-end shield can still end up inside the box.
Often this QRN manifests as a family of ~60 kHz separation lines in the 20-30 MHz region. Rob, AI6VN has had good success in mitigating these, without additional enclosure shielding, through use of a USB/WiFi dongle which bypasses the wired LAN connection and attendant spurious energy. Perhaps he will post some documentation of that as well.
Best,
Glenn n6gn -
Distortion & Noise Measurement of a new KiwiSDR, June 2018
An antenna switch for the KiwiSDR
Attached is a pdf that describes my current efforts to design and build an antenna switch for the KiwiSDR and the reason behind them. I'm posting it in case it may be of interest or useful to KiwiSDR owners, not because I'm interested in manufacturing or providing one - I'm not.
This is subject to revision...
