- jks
- 30,007
- 213
- Location
- Tauranga, New Zealand RF82ci
- Callsign
- ZL4VO/KF6VO
- Additional information
- KiwiSDR support email: support@kiwisdr.com
HF Broadcast Schedules
It's buried in the bug list, but there is an entry that says:- Use info from public databases, e.g. shortwave broadcast schedules (EiBi)
"Initial mode" & "Initial BCB channel spacing" [fixed in v1.150]
Ugh. You are absolutely correct. Looks like I broke admin page menu select callbacks when I did a code cleanup a little while ago. I'm surprised no one else has complained about this until now. It affects 8 different menu selects on the admin pages. I'll release a fix for this right away. Thanks for mentioning it! -
Suggestion - insert google analytics code from admin panel
Sound recording from multiple opened browse windows for diversity reception?
You can see all the current options by doing: python kiwirecorder.py --helpI didn't write this code, and I don't know python, so requests for improvement should go to the original author: https://github.com/dev-zzo/kiwiclient -
