- jks
- 36,413
- 646
Maximum possible number of simultaneous users
Same as with Kiwi-1. The number of simultaneous users varies depending on the FPGA configuration selected on the admin page, "mode" tab.
But there are compromises as described in the text on that page. In 8 channel mode only 2 can have a waterfall. In 20.25 kHz wide audio bandwidth mode there can only be 3 channels etc.
v1.802
From the CHANGE_LOG file:
v1.802 February 7, 2025
Added support for multiple iframe instances, up to 16. (thanks VK3KHZ)
Admin > Extensions > iframe has a new button called "populate with standard entries" which
will add 6 new iframe entries in addition to the new "DX spots" default added last release.
They are: solar conditions, K-index, HF propagation, lightning map, and aurora.
Fixed bug preventing change of proxy host name in certain cases.
v1.801
v1.801
Some relevant to NZ would be cool too.
As an example, the lightning map (example: http://sdr-amradioantennas.com:8073/?ext=lightning) can specify a lat/lon. So a NZ Kiwi could center the map over NZ.
v1.801
The next release will support multiple iframe definitions so you can have several custom entries in the extension menu.
So I'd like to start a collection of iframe URLs that people have found and setup on their Kiwi's. We have the default SK6AW spot list now. And I'm aware of the Blitzortung.org lightning map that the VK3KHZ Kiwi's have. Someone must have one for solar conditions, right?
Please drop a link below to a Kiwi that has an interesting iframe. Or email to support@kiwisdr.com
Thanks!
