la3rk
- la3rk
- 1,865
- 3
Yes, understood. I am struggling to understand the code, but have come as far as seeing the underlying commands going to the kiwi. Is the KiwiSDR web socket documented somewhere? Would be easier than deciphering the debug output from kiwiclient.py. …
I have the kiwiclient library running fine, but it is stuck on one frequency once started. The question is how can the rx be retuned/reset within through that library. Using catsync via wine on linux is not a good solution. Amongst other catsync re…
--help on kiwirecorder.py only states that -f option includes frequency. I am looking for the possibility to tune the kiwi according to eg rig setting, ie an effective 2nd receiver. There must be some way of changing the frequency once a channel to …
I am currently using dyndns to access a raspberry on that location. Follows the dynamically allocated ips I get more or less every day from the provider. So accessing a kiwisdr directly is just a matter of forwarding a port on the 4G router. 73 de …
Thanks, seems this python script is a good start. Ideally I would use this to get audio out from the pc and ask the kiwisdr to follow eg thhe second rx on the K3. Ie an effective 3rd receiver which can be located remote and only use the audio bandwi…
