- jks
- 30,238
- 220
- Location
- Tauranga, New Zealand RF82ci
- Callsign
- ZL4VO/KF6VO
- Additional information
- KiwiSDR support email: support@kiwisdr.com
Sorry, I got called away by a conference call. If your Kiwi hasn't updated to v1.677 before 3:00 UTC then when it does it will get the change. If it updated prior to 3:00UTC then go to the admin update tab and do a manual build via the "build n…
Okay, adding this feature now..
So after a power up, as opposed to a software restart, the Kiwi waits extra time before starting the server. This is so if the power up is from a general power failure there is time for other network equipment to restart and stabilize before the Kiw…
Please try this: Push the "Click to (re)register" button for the proxy and get it working again. Then use the "Beagle power off" button on the admin control tab. And power up just the Beagle (not the router). See if it works afte…
Can you cause the failure now so I can look at the proxy server and see why it isn't initializing the proxy correctly. Let me know when it's in that state. Thanks.
If you're going to use the reverse proxy then it doesn't matter if the router has a port 8073 NAT entry or not. That's the reason for the proxy in the first place. So if the auto-add NAT (via UPnP) is failing, for whatever reason, it shouldn't matte…
So with Debian 8.5 you could go to the log directory and see if there is a problem: cd /var/log du root@kiwisdr:/var/log# du 4.0K btmp 4.0K dmesg 4.0K ntpstats 4.0K syslog.2.gz 4.0K syslog.3.gz 4.0K syslog.4.gz 4.0K syslog.5.gz 4.0K syslog.6.gz 12K…
Okay, I added a plugin that allows some content to be added to profiles. For now just Location, Callsign and "Additional information". Let me know if you think we should have others. Look at my profile as an example (click "jks" …
journalctl: unrecognized option '--vacuum-size=10M' There's your problem. It seems that option is not available on the stock Debian 8.5 journalctl. But it is present if you do an update to 8.11 (I just tried it here). That other problem looks like a…
It's a pity that this form doesn't allow you to modify your profile.. It doesn't? I can probably fix that..
The ADC is just under-sampling stuff above Nyquist. That's why you often find ADCs with huge input bandwidth specs way in excess of their sample rate capability. With the right image filtering ahead of the ADC the Kiwi could under-sample stuff above…
I had a sig gen (hp 8657) connected to a Kiwi for other reasons. So tried a few things: Kiwi-1, 42.5M in, 24.166M out, 21 dB down Kiwi-2, 42.5M in, 24.166M out, 24 dB down Kiwi-1, 47.5M in, 19.166M out, 31 dB down Kiwi-2, 47.5M in, 19.166M out, 33 d…
There's a bug with option 1. Introduced in software release v1.667 and fixed in v1.676 and. I believe it only keeps the email link from working if you are using Firefox.
It would be interesting to see the spectrum display (including the dB scale on the right) as well as peak S-meter readings with the passband centered on the signal. It's impossible to judge the strength of these signal looking at the waterfall alone…
Yeah, I very much doubt this. But I suppose now I'll have to spend time setting a Kiwi here with that old release so I can do some A/B comparisons. I really don't have time for this. I am fighting so many fires. So many emails..
Thanks Carl for reporting this. Always interesting to know there are people actively probing the API as opposed to bots just running around.
Hi Frank. Yes, quite right. Subsequent to my initial posts in this thread the Austravel Safety Net was mentioned by Martin. I added their channels to the Selcall frequency menu. They even have two Kiwis of their own located on each coast accessible …
This is from the Wessex Kiwi-2 using DCF77 77.5 kHz. Seems okay. But it's just one data point. https://forum.kiwisdr.com/uploads/476/R4KWG9ZTUE0T.png
"no config pwd set" in this case just means there is no user connection password set. Which is how almost all public Kiwis are configured.
On another Kiwi is see where this IP address is connecting every 30 seconds for a short amount of time. I've added the entire IP range (Russia) to the global blacklist.
Those look normal. Remember that more messages appear in the admin log tab than the Linux syslog. Because the log tab also contains messages that are considered "debugging", hence not syslogged.
I completely forgot about that.. Thanks!
Okay. But history has shown that, at least in the case of the Kiwi, being on the bleeding edge of what the Beagle guys are doing w.r.t releases has no benefit and significant downside (consider the recent ssh/liblzma issue).
Agree with Martin. If you want to use the DUC you have to read the documentation. The link is right there highlighted in yellow on the admin page connect tab, DUC section. After entering your noip.com information you've got to press the "click …
What Beagle release is using Linux 6.1? I haven't seen that (but admittedly don't 100% keep up with what they're doing). I thought about using PREEMPT_RT way back in 2014. But I didn't know anything about it. I figured if the entire project was pred…
Hi Jeff, I have to do this manually (and I'm obviously tardy in doing so). I download the latest .csv file from eibispace.de and run it through a custom C program I wrote that parses that file and builds another file that is compatible with the DX l…
It's been years since I did this. But there's some code commented-out in the FPGA programming routine that I think does a loopback test of the SPI interface. You have to remove the Kiwi board and jumper the MOSI and MISO signals together of course. …
Your responsibility. But be careful. We had plenty of trouble in the past (mostly with Debian 8) because people would jump the gun and update/upgrade before I had cleared it. The problem wasn't with what Debian had done but rather with what the Beag…
Okay, /snr?measure (from the local network only) added to /snr interface for the next release.
