ShaneBrook
Can You Have a Check Box To Activate a Floating Window That Stays On Top Of The Current Window That Shows The Tuned Frequency In Selectable Font Size and Type for Sight Impaired People?
Thanks.
- ShaneBrook
- 320
It's just the TAB that deletes... Sorry, Yes I explanted it in a confusing way....
I see now..... Thanks....
is this ok? I did Kiwi address + Status
Ok........ Thanks, That was easy.....
Webpage Tab Now works..... Thanks
I did what you said..... It worked! ..... Fixed.... Web Page Tab Stuff won't update with my Info added...
Ok, What are the commands....
Here it is............... Aug 6 00:39:43 kiwisdr kiwid: 00:00:00.857 KiwiSDR v1.550 -------------------------------------------------------------------- Aug 6 00:39:43 kiwisdr kiwid: 00:00:00.860 compiled: Aug 5 2022 20:36:59 on kiwisdr Aug 6 00:…
PuTTY and WInSCP I use 192.168.xxx.77
This use to work.... kiwisdr.local:8073 Now it Doesn't I connect this way: 192.168.xxx.77:8073 192.168.xxx.77:8073/admin 192.168.xxx.77:8073/Status
Update finished... No errors.... Still can't get https screen... Putty and WinSCP works.... The Opera Web Browser was no screen... It did connect though..... Should I reinstall from old version... Then update?
Can I force an update? cdp then up ? The last update I saw was v 1.545, maybe something happened on one of the others? The last time I used the KiwiSDR Opera wouldn't work hade to use FireFox or Microsoft Edge. How do I know what OS Version do I hav…
Thanks for doing this.... It works great for me now.....
I am doing this for US CB Radio Band.... Like this: 26965 - 27405 MHz CB Radio USA Armature show on band menu only 10 27025am the channel spacing stays the same.... 5KHz... I even did server restart.... Thanks.....
Wish it had a Am Stereo Led light..... That would be cool....
JKS, Did you try that combination? That's when the ones that are fixed change frequency's....
Yes, You are right.... It now works ok.... Try: (rx0) 60M_EU (rx1) ISM_6 (rx2) reguler use (rx3) IWBP This is what I had..... When it worked like I explained. Thanks.....
JKS, You Said: What do you mean "never goes back to ISM_6"? When Looking At Status Page of Kiwisdr and the RX(Number) you can see the Frequency... It starts at 6781.5.... Then the frequency's change going up..... and if you watch for a wh…
Is there a Program to do Packet using IQ Mode? For Windows 10 and Linux?
Is the 80_IU & 60_EU scanned with IWBP? What is 80_IU for area for? And the 60_EU.... Is for Europe? Thanks
Yes, I also Like this Feature. Works for me so I can have more channels open for sharing my KiwiSDR .... Thanks.....
Thank you for so much help, Sir! ------------------------------------------------------------------------------ zcat /var/log/user.log.4.gz > /tmp/kiwi.log; zcat /var/log/user.log.3.gz >> /tmp/kiwi.log; zcat /var/log/user.log.2.gz >> …
Who put in the DX Eibi Data base? Did they do it as Automation or Manual entry?
Where is the file for the DX Labels in the Kiwisdr ? so I can save it.....
Yea... Transmitter Site Lat & Long and Distance in KM and Miles Selectable & angle from North and Propagation like Number of hops F1, F2, E layer, Sporadic-E and D Absorption. Wow Man Boy what more would you want ?
Ok... I read it... OK, Thanks....
Yes....
No, Just private for now....
Man.... I shire like this KiwiSdr Receiver, It's the best !
