DX Label Edit for Extension Field
When I click on Label for NavText 518 KHz I want to get into the right DeCoding Parameters....
170 Shift
100 Baud
4/7 Framing
CCIR476 Encoding
How to do this..... ?
Thanks....
  • Just put "NAVTEX" in the "Extension" field of the DX label. Then the NAVTEX extension should be automatically started when you click on the label. Also, the label will turn purple when moused-over instead of the usual yellow to indicate an extension will be started.
    Starting the NAVTEX extension automatically uses all the decoding parameters you mention above which are from the FSK extension when you select a NAVTEX entry from the Maritime frequency menu.
  • Ok........ Thanks, That was easy.....
