SWLJO43
Yeah, the new one is extremly faster, than you John.A single WSPR new decoder is running and running.After starting a second WSPR new decoder, without anything to decode, it is runing and running.After starting a third WSPR new decoder, the KiwiSDR is resetting after arround 30 minutes. :-(
If i repeat the steps mentioned above, this error occurs every time.
- SWLJO43
- 83
- 25
It also runs on an PC with Debian cu Dirk
VP6D via FT8 on 7.056 kHz (Image)
Hello, in my case i use an older Computer and i installed - debian-9.5.0-amd64-netinst - dpkg -i wsjtx_1.9.1_amd64.deb - apt-get install bc - apt-get install ntp - apt-get install python-numpy - apt-get install curl and your kiwiwspr.sh to /home/p…
Fantstisch, thanks to John and TDoA-Scripter and the good KiwiSDR's that I can use. Dirk (SWLJO43) (Image)
Super, (Image) 13760 kHz, Kujang (200 kW)
Hi, China Radio International Kashi-Saibagh (Coordinates: 39°21'40"N 75°44'43"E). (Image) Dirk SWLJO43
Hello John, the cluster markers are very good, but my Kiwi's are so close together, so i cannot click them. Hm? (Image)
Fantastic triangulation, bull's-eye (Image)
Hi, here in Hamburg/Germany good signal. RST 465 https://www.youtube.com/watch?v=41D4zknIQDA
Thank you, is solved.
Hi John, i am adding a new entry in the DX edit panel, while the next new adding the Kiwi reboots. DX edit panel: First entry = OKSecond entry = reboot I had this testing on two Kiwis. cu Dirk
Hello John,I love it. It is very easy to use.Under Audio / Volume is no "%" indicator like "Noise trheshold". Dirk
Hi,i am using.ALE_32 -> MIL-STD 188DREAM211 -> DRMEasyPal -> DigiSSTV fldigi -> RTTY, CW,...MMSSTV -> SSTVRXSSTV -> SSTVMUTLIPSK -> RTTY, CW, SSTV, DGPS, ...NAVTEX -> NavtexOpera 1.6.5 -> Opera ELF, VLFPC-HFDL 2.042 -> …
Okay, its worked with the IQ Mode, but the "dx.json" don't like entrys with "IQ". ,[3965.00,"IQ","DRM%20RFI",""] Dirk
Hi,yes i am hearing the audio stable.Hm? it's a long time ago. I followed the intruction from "https://www.rtl-sdr.com/tutorial-drm-radio-using-rtl-sdr/" and downloaded the "faad2_drm.dll" file. Ooops, downloading the file "…
Hello, i tested it with Windows Dream 2.1.1 with the SDR http://kiwisdr.sk3w.se:8073/?f=3965iqz10 positiv. (Image) Thanks Dirk
Hello John, here is the same: the fax.ch0.png is empty. The Fax decoder is working well. Thank you. And now a JT65 decoder with reporting to pskreporter.info :-) cu Dirk - SWLJO43
I have tried it with the EDGE and it works. Thank you
I have stable signals on my kiwisdr on (khz): 1104, 3312, 4416, 5520, 6624, 8832, 9936, 12144, 13248 17664, 20976, 23184, 24288, 25392 and 26496 It looks as if the 1104 khz is the main frequency and the others are multiple of 1104 khz, hm?
Yeah, the new one is extremly faster, than you John.A single WSPR new decoder is running and running.After starting a second WSPR new decoder, without anything to decode, it is runing and running.After starting a third WSPR new decoder, the KiwiSDR…
Hello, i am using the EDGE-Browser without problems.
Hello jks, thank you very much. The uploads from kiwisdr to WSPR are up and running again. Greetings Dirk My view in the WSPR viewer:UTC dB dT Freq dF Call Grid km dBm 1440 -12 -4.0 14.097103 -1 EA7EOO IM76 2199 37 (5.0 W) 1442 -…
Hi, sorry, my text was too short and my Image wasnt uploaded. :-( (https://goo.gl/photos/BvWpqvGEHP9VzxPy8) - uploads from kiwisdr to WSPR are broken cu Dirk
Hint: whenever i'm change the value in S-meter calibration, than i have to click on the yellow IQ bal button again.
Wow that helped. I openend the IQ display, tuned to an AM Radiostation and realy the dots are not centred. On click on the yellow IQ bal and my problem is solved.Many thanks and greetings from northern Germany.Dirk SWLJO43
