- Powernumpty
- 5,429
- 27
"UPDATE: switching to new version" should mean it has worked. From another thread - proper instructions (without requiring SSH) (jks) If the admin page works go to the "update" tab, click "build now". Then the "con…
Can you ssh to the Beaglebone and "tail -f /var/log/messages" There are other commands specific to the Kiwi (cdp, ml etc) but for now that should show where it is getting to and any fault messages like paraphrased "can't get to githu…
Can I just check you did NOT put the sd card in the slot? I'd power cycle it, if it is new (no configuration) and you have the SD card to hand there is little risk.
OK so for you to have changed from provider 1 to provider 2 who made the required changes to your router? Things like ISP service to connect to, and credentials to validate as a paying user on the service? If I changed here, I would need to enter th…
I wonder if the new connection details for the new service have been entered correctly or if they are using a service like TR-069 and have even remotely changed the WIFI. TBH I saw the form factor and assumed it would default to mobile data.
@o00scorpion00o kiwirecorder.py is mechanism for taking the data stream from the Kiwi SDR and recording/processing it locally, in the same way Firefox is software for taking HTML (website) data and rendering it locally. If you saw Firefox being use…
I'd start by restarting that phone. "I can't open any other sites either?" sounds like a data routing, mobile network or data limit issue. Restart the phone (not just lock/unlock) and try a big name news site in your area. Then once that w…
I wonder if the general coverage shows them where the atmosphere is being seeded to be reflective for over the horizon radar. If new military operations were planed hot spots may be detectable between area to be surveilled and the viewing radar? Jus…
I think seeing the Kiwi log rather than the recorder would be good, to make sure it really is an issue caused by kiwirecorder. By "Kiwisdr was not running" I don't understand if you mean the recording did not start, if there were other se…
Use SSH, get to know some kiwi log commands, there will be clues we are not seeing. I see the router shows the Kiwi at 1Gbits/s which the green is not capable of at the physical level so small things like that you could be testing and narrowing down…
https://forum.kiwisdr.com/index.php?p=/discussion/comment/13151/#Comment_13151 [updated] As mentioned in other posts below you'll probably have to hold down the Beagle user/boot button for the Beagle to properly boot off the sd card. ---- At a guess…
It can be awkward if the process is unfamiliar but I do find going from the original image and letting it update, although time consuming, avoids a few pitfalls of making an image after install and trying to write to new hardware. As there are very…
What support do you need? normally it is case of using the original install SD card and then just letting it update. Just make sure you are careful about lining up the pins and it should be event free. Is there a thread on what happened to the last …
I seem to remember it being a browser decision and I can see a few scenarios where it makes sense. Security could be an issue if the browser is tricked into processing audio that is something else. Alternatively if site was slow to load then kicked …
Patience is a virtue. It does need to see the hardware is communicating, helps with fault finding.
It is already running under voltage so if it is noisy it might be wear. You could peel the sticker off the fan and oil the bearing/shaft. I have only run the Kiwi+Beaglebone without the fan in another case (closer to the BeagleBone and lots of metal…
Probably depends how you are accessing it. Set a fixed IP address for the Kiwi in your router and try accessing it with that (use http://my.kiwisdr.com/ to check the address)
https://forum.kiwisdr.com/index.php?p=/discussion/2435/forum-rules-and-etiquette#latest There are previous discussion on personal reverse proxy but it is probably worth discussing off the Kiwi forum as it opens many more support issues from "I …
Wonders what people are talking about, goes to check... Wow.
65.20.112.0/23 Added to my router Vultr - Florida (actual address 65.20.113.188)
The first rule about kiwi bot fight club... Thanks for 108.61.176.0/23, I had a much more expansive entry in my router.
I'd try the Kiwi serial number, the root password is reset on the basic version like that, as part of the upgrade path but I can't honestly remember on the AI.
We have seen a missing gateway before. "route" I think works across all versions to show that look for the gateway, it might just show as "_gateway" in which case you could try "ping _gateway" to see if it resolves and …
What OS and make of audio chip? --tests-- Just tried with Brave (closest I am prepared to install to Chrome) very slight audio, tried a few times with Corel screen capture and blue screened my laptop. Waterfox (like Firefox) definitely longer and s…
Could it be clearing some buffered audio? Was the frequency heard one you use or the default in Kiwi config?
Also check the IP range for Github is not in the blocklist, I managed to do that somehow.
So you want the frequency display, which gets quite cramped on mobile devices, to have more characters? I don't assume the frequency is accurate to 10Hz, let alone single Hz, so can't really get why it is of general value.
There is normally a fair amount of mixed mode noise around switchers so a lot depends on the supply and how it is getting in to the radio. I won't pretend to be any kind of expert but in my tests it's important to stop radiated noise and doing that …
wsprdaemon is the way to go, designed for exactly this and more. Two in a case should not be a problem, I ran two in a metal 3.5" hard drive enclosure for ages. I'm not saying try a hard drive enclosure as it is tight (height mainly) but two Ki…
Brendan, whatever that issue is/was, I don't think it is related to the Vultr IP ranges. I just connected to your SDR without issue. Stu
