https://forum.kiwisdr.com/index.php?p=/discussion/comment/18671#Comment_18671 Thanks! And thanks again for the v2. Really loving it!
https://forum.kiwisdr.com/index.php?p=/discussion/3073/kiwisdr-2-reverse-proxy-will-be-enabled-by-default Since this is HAM related, we could possibly reserve some ham space out of 44/9 for the proxy project. depending on country this could be from…
Just a headsup, but payment may be flagged as fraud by the credit card company, just had it happen to me upon ordering 2 units. They deblocked my card once I confirmed the payment was legit, but not only 5mins after paying it was flagged for fraud
Interrested in 2 pieces of the KiwiSDR2
This will be awesome! I loved the v1, hate myself that I fried it and will DEFINTATELY be purchasing the v2.
https://forum.kiwisdr.com/index.php?p=/discussion/comment/16584#Comment_16584 That makes sense :) tried the latest update but still no joy, so thinking something has gone wrong with the board unfortunately.. am trying to find another board (or compl…
I think you might have posted that comment in the wrong thread :)
kiwid keeps running though, even after it closes the webserver: -- # ps auxw|grep kiwid root 2831 99.0 2.7 171928 103748 ? RL 08:15 9:09 /usr/local/bin/kiwid -use_spidev 1 -bg -v 1.621 # netstat -aneput|grep kiw tcp6 413 0 :::807…
It is a wierd issue indeed.. Just set the "External ADC clock" to yes on the config page and disabled the updating of the ADC from GPS too but issue stays the same unfortunately. As soon as I go the openwebrx it hangs and after a few minut…
Choke removed, but have not jumpered across the pads yet, should I because the barrel in the kiwi is not in use as everything should be powered by the BB-AI64 now if I'm not mistaken? After 10 or so minutes the frequency stays stable around 65.8Mhz…
I'll measure the voltage across the ADC this evening, did not think of that yesterday.. I'll also remove the T301 choke and see if that solves anything, fingers crossed :)
https://forum.kiwisdr.com/index.php?p=/discussion/comment/16459#Comment_16459 kiwid does not crash, it just hangs and nothing in the log. Even when you add wspr listeners and then restart kiwid the kiwi daemon just hangs just after it starts the wsp…
OK, so I checked voltage levels & signals and here are my findings T301 shows 5V on input side, 0V on output side when measuring between the 2 pins of the T301, but 5V on each pin between the barrel ground . But if I'm reading correctly then th…
can check the BBG too this evening, that one does not power on anymore. Migrated the kiwi board to a BB-AI64 now, but the HF part of the board is not working for some reason, GPS works fine, but whenever I try to access the HF radio in any way the k…
That is indeed what I will be inspecting this evening. Currently the GPS works and it locks and updates the ADC from what I can see in the admin page. But anything connecting to the HF radio part locks up the kiwi daemon, wspr from the kiwi itself, …
Yeah the admin page works fine until I try to access the radio part I can see the GPS and it even gets a lock with the correct coordinates and I think it syncs the ADC clock too Tried changing the nr of radio’s, but that had no effect. will attach …
Ok, followed the instructions for the BB-AI64, updated the BB, cloned kiwi repo, compiled, installed board, .. Main config part is done via the admin if, but trying to access the radio side of kiwisdr hangs. This also results in the admin webpage no…
allright no worries then, I'll order the AI-64 and reinstall and keep my fingers crossed. I love the kiwi. It's a very nice and all-inclusive webSDR and I would love to get it back online. Thanks for answering and the response time was way below wha…
The issue is that the reverse polarity entered the Kiwi board via the RF-IN port as the polarity was reversed on a Bias-T and that either sent current back to the Kiwi board which then propagated to the beagle, or in best case just shorted the beagl…
