LA6LU
LA6LU
12
  • Thanks again John, It helped re-trying pushing in the cd-card, until i saw withdmesgthat the card was accepted. The copy, diff etc. went just fine and the kiwi is up an running with everyhting I could wish for. Will do some small changes in my conf…
  • Many thanks, I am almost there and the most critical part is done, but I have problems restoring original config files. (see below). https://forum.kiwisdr.com/uploads/235/OOCEVKF8RC68.jpg As reference, here is part of what the instructions says: Mou…
  • Hi, One of my two Kiwi's stopped worked for a while ago. It was impossible to access it, even locally and two of the blue LEDs blinked in sequence, suggesting that my Kiwi's file system had gone corrupt. Possibly because of a network glitch during a…
  • Update: I just bought a PCTEL 40dB GPS antenna from the US and 10m coax from China, all on ebay. The cable is fitted with a TNC male and SMA male which will fit the PCTEL and the Kiwi. Thanks again guys. Your help is very much appreciated. :) 73's G…
    in GPS antenna Comment by LA6LU February 12
  • "Either of those might be overkill but you'll never visit a GPS problem again with one of those probably installed. The excess gain will overcome any feedline loss." Thanks for the link, that got me started on ebay. As mentioned above, I t…
    in GPS antenna Comment by LA6LU February 11
  • "In your case I think it would be worthwhile trying to extend the GPS cable." Yes, at least the cheapest way. :) If I just could get the (original) antenna out and on top of the terrrace roof, I think it would change to the better. The dra…
  • Hi Chris, I am having just partial GPS coverage here in Thailand for my new Kiwi here. May I ask about your 40 db antenna, where you bought it (link) a and the price for it? Also see https://forum.kiwisdr.com/index.php?p=/discussion/2823/gps-antenna…
  • Thanks Guys, I really appreciates your great feedback. :) My antenna is stretched out as far as the cable length allows it via a hole in the concrete wall, to under the ceiling of our terrace. The antenna is attached to the ceiling with some strong …
    in GPS antenna Comment by LA6LU February 10
  • Is there news about this fan or did the shit hit the fan, so to speak. ;) I want original replacement fans if possible. It do help if the quality is better too as the original fan from Seed is a joke with such a short life span. Update: Found it in…
