KU4BY
- KU4BY
- 259
- 1
@jks Thanks! I just received the shipping e-mail a couple of hours ago.
Well dang, I'm #1072....
Thanks, I didn't get a chance to test it again prior to my device updating but it is working fine now.
I pasted the IP address and positioned the cursor right behind it and hit enter like I have done numerous times before but the cursor just kept dropping down to the next line. The box didn't flash or anything. Perhaps the kiwi was glitching because …
At least 1 for me as well. Probably 2 though.😂
Cool, I never listen down that low. I am fairly close to the Atlantic and my noise floor is typically pretty low so I guess it makes sense. Thanks for checking it out.
Thanks, so now it sounds like China is trying to use my kiwi to spy on US Navy sub comms? During the day I have no reception from PR except around the CB band but I can hear a beacon from there at night on lw so maybe so. Perhaps I'll unblock them…
I got a couple hits from "directTD0A_v7.02" today. It was connecting every few minutes and parking on a single frequency. Anyone know if this is a legit use or have they just changed the way they do things? I kicked them a few times and th…
@ChrisSmolinski Yeah when we first started noticing this, they weren't showing up in the Admin page because of how they were accessing the receivers so there was no way of kicking or banning them from the GUI. You had to do it at the OS level and I'…
My kiwi has been pretty quiet but I had a couple more kiwirecorder hits this past week. One was an OP in China recording EAM messages in one hour segments every hour on the hour so effectively tying up a channel for a whole day before I caught it. I…
@o00scorpion00o Your situation sounds completely different with the exception of kiwirecorder.py being used. Kiwirecorder.py is a python script where you can automate to record data from the kiwisdr's. Anyone and everyone can use it and if they leav…
Sorry about that. I update the list under Admin every time it says a new list is available. I figured if they were scanning me then they weren't on it. I'll verify next time. Thanks!
And I just got hit by 2 more. May 7 13:06:44 kiwisdr kiwid: 22:08:24.453 01.3 2 292.97 kHz WF z8 "kiwirecorder.py" 216.238.81.138 Mexico City, Mexico (LEAVING after 0:01:13) May 7 13:06:58 kiwisdr kiwid: 22:08:38.647 01.. 3 4…
Thanks @jks . Here's another. May 6 15:16:54 kiwisdr kiwid: 00:18:34.490 012. 2 58.59 kHz WF z8 "kiwirecorder.py" 141.164.57.204 (ARRIVED) May 6 15:18:29 kiwisdr kiwid: 00:20:09.538 01.. 2 28125.00 kHz WF z3 "kiwirecord…
I had a couple more yesterday. Piscataway and Houston. May 5 14:22:11 kiwisdr kiwid: 1d:00:09:53.524 0... 1 28125.00 kHz WF z3 "kiwirecorder.py" 104.238.132.42 Piscataway, New Jersey, USA (LEAVING after 0:01:3 3) May May 5 15:34:2…
I got a new hit last night from the Netherlands. They were hitting me every 20 to 45 minutes or so for a bit. Just sharing. Apr 30 19:30:32 kiwisdr kiwid: 3d:16:05:34.548 0... 0 58.59 kHz WF z8 "kiwirecorder.py" 199.247.26.127 (AR…
The amount of time they stay connected has never been consistent on mine. It's always between 1:31 and 1:34. Here's an example from just a few days ago. All from the same IP address and you can see how the times fluctuate. https://forum.kiwisdr.com/…
Good morning @jks , I was backing up my sd card from the Admin page backup tab yesterday and about a minute or so in, I got the message about the server closing the connection. The console window was still scrolling when this happened. I'm assuming…
I got scanned by the Florida address last night also. Apr 16 10:18:52 kiwisdr kiwid: 6d:19:54:37.828 01.. 0 58.59 kHz WF z8 "kiwirecorder.py" 65.20.113.188 (ARRIVED) Apr 16 10:20:24 kiwisdr kiwid: 6d:19:56:10.547 .1.. 0 28125.00 kHz WF…
I had a feeling I was jinxing myself when I made that last post this morning. They have another IP. Apr 14 15:04:14 kiwisdr kiwid: 5d:00:39:59.867 0123 3 58.59 kHz WF z8 "kiwirecorder.py" 108.61.177.90 (ARRIVED) Apr 14 15:04:30 kiw…
It's been well over 10 days since I've had a WF only connection by anything other than "SNR-Measure." My receiver has been working fine and I've had no random restarts during that time. The list of IP addresses that I have logged for these…
Well I was close. It was a little over 2 days but here's a new one. Mon Mar 28 09:31:08 7d:23:49:44.193 0... 0 PWD kiwi W/F ALLOWED: no config pwd set, allow any (167.179.65.161) Mon Mar 28 09:31:08 7d:23:49:44.700 0... 0 L 58.59 kHz WF …
Thanks @jks, that would be cool. I've been monitoring my logs a lot more lately and along with giving me a better understanding of them, I've noticed somewhat of a pattern. I've been blocking the incoming IP address each time I catch them, but it …
@WA2ZKD This thread has nothing to do with blocking legit users. It's about blocking bots that are making waterfall only connections every hour taking up as many channels as they want while denying service to legit users.
I'm much more of a "set it and forget it" kind of guy. I don't bother with the logs unless something isn't right like all 4 of my channels are taken up by ghost connections...😂 Since this happened though, I have been checking them quite of…
I got a new hit today and I'm loving the new log settings. I haven't re-enabled the setting restricting to one connection per IP yet. I am curious though, is there a way to disable WF only connections? Or even just block kiwirecorder.py connections?…
@rz3dvp OK, I thought you meant that you deleted browser cookies as a troubleshooting step. I deleted mine and got the same result you did.
@rz3dvp I just upgraded to v1.500 and my audio volume was right where it was before the upgrade. It did not go to 0.
Well I can report that since I blocked those 7 IP addresses above about 8 hours ago, I have had 0 kiwirecorder.py connections and no issues with the receiver.
I am in an area with lots of military bases but most of them are at least an hour away. I think I might just break out my old trusty "Linux for Dummies" book and setup a cron job to create a daily report of all of these generic kiwirecorde…
