Gibsonmb
- Gibsonmb
- 76
Guys, how do I make it so my CPU speed is set to 1.18Ghz permanently so that when it reboots it does not revert to 1.5Ghz? Do I need to nano a file somewhere? I want to set the cpu speed that bit slower whilst I'm sorting out the cooling.
Back on-line in public now. Just waiting for larger end fan to arrive to supplement the Farnell cape fan as temp still a bit high. I will also raise the sdr away from the fan cape with header risers..... also awaited. Thanks again for your support
Great, looks to be working now. I've powered it down short term because now of course it's running at 1.5Ghz and thus I need to tweak the cooling. I also need to do a bit work on the filtering on the linear PSU feeding it and move the sense leads cl…
I agree on the quality of this radio and also, not supporting low value, low support clones. I bought this in 2016 and it's still going strong. I bought it as a complete kit with the BBG and added the SEEED Studio aluminium case. I've got an SD card…
Done...
I only have the router from BT. It has a firewall build in but once I've set a port open, I can normally log in without problem from other locations. The firewall can be turned off but you still have to put the port routing in. I can of course set t…
Not sure why the ssh is being closed. I've just routed it straight through ( I hope). Should I leave it set up this way for a few days in case you get a change to look at it again or will you take a look on a test system of your own? regards Mike
http://forum.kiwisdr.com/index.php?p=/discussion/comment/11704#Comment_11704 Ready for you John as per email
root@beaglebone:/home/debian# i2cdetect -l i2c-3 i2c OMAP I2C adapter I2C adapter i2c-0 i2c OMAP I2C adapter I2C adapter
http://forum.kiwisdr.com/uploads/362/U05QTKQ5MXYO.jpg Just for completeness
OK John, many thanks. I'll open up port 22 tomorrow and route it to the BBAI. Is there a way I can advise you of the log-in details a bit more privately?
Yes it's genuine, bought from Martin Lynch &S or Farnell here in the UK in about 2016, has your name printed on the PCB John. I can send a photo of the serial number hand written in black pen on a white background if you like. It must go into a…
Just to be sure of the PSU, I've hooked up a bench PSU set at 5.2V and max of 6A, The BBAI/SDR combo peaks up about 2.1A during start-up and settles at 1.3A no activity. Plugged it back into BBG to make sure I've not bricked it. No, still working fi…
that I was using on the BBG
yes, via the cape barrel plug with a 4A 5v PSU
This is what I get with that tail command... Apr 7 12:44:49 beaglebone kiwid: 00:00:00.499 compiled: Apr 7 2021 12:07:08 on beaglebone Apr 7 12:44:49 beaglebone kiwid: 00:00:00.500 -debian 9 …
So now, I've done a make clean, make, make install again with the sdr plugged into the BBAI. Same state afterwards. All processed OK, no error messages. Rebooted. Just the same. Once additional point, If I go to port 80 I get the cloud 9 IDE so I kn…
OK, I'll give it a go. Was just slightly worried that if I built the BBAI with the SDR plugged in that it may change the configuration of the SDR in some way and I might not have been able to go back to the BBB if the BBAI did not work out. You've a…
Thanks, that's very encouraging. Just for info, Chrome on my Macbook does not exhibit the popping problem
All very well Canary not having the problem but Canary is somewhere even before Beta. When might we get a fix for this if we stick with released versions of Chrome? I've downloaded Firefox fro now to test and the problem is not there on Firefox. Bef…
