Cheeto_Bandito
- Cheeto_Bandito
- 62
merci pour la rapport, et je suis d'accord. je pensais que starlink rendrait ça très difficile .. l'antenne sera beaucoup plus haute cet été et j'espère que mes voisins iront camper hihi
https://forum.kiwisdr.com/index.php?p=/discussion/comment/18273#Comment_18273 you're close .. around here the starlink satellite dish sits on the roof. that goes to a router inside the house direct with no ports of any kind. so everything isn't bu…
Hey Mike, I appreciate the heads up. I have the adapter cable in my starlink shop cart but haven't yet pulled the trigger. theres a few times now i wish i had a normal router rather than all this proprietary jibberjabber. i was thinking about gra…
you're correct. the dishy connects to the router in the home with no ports available. everything else is wifi. i already have a subscription to protonvpn for their port forwarding and tunneling features, but i'm a little ahead of myself here. i …
i'm quite familiar with running a business and the hours it demands so i'm glad i was able to help sort out an editing boo-boo. i'm running starlink with a pretty normal setup -- no spare port on the ethernet cable. should i look around for one of …
Nah this just is a switching supply, there's no on/off switch on it. Turns out it's 2.8A, so maybe it's slumpy but idk, should be enough. I'll see about a different supply before I start squawking too hard.
Roger that. I'll have to buy one, Im a new(ish) ham so I don't have much of a pile of debris and parts yet. Thanks!
I dont have a bench supply .. I've got some basic stuff like a multimeter though. I popped it out of the case it and at the back of the plug (looking at the pcb board) the terminals show 5.65v. Which is what this PS puts out with no load -- same is …
https://forum.kiwisdr.com/index.php?p=/discussion/comment/18214#Comment_18214 whats slump mean? i see the recommended switching psu in the write ups are 3 amps, but the write up says the unit will eat near 1.5a at peak.
wait a sec, just to be clear the power supply is 2a peak, but i measured it with a 1a load.
mmm i do love breathing life into antique threads. i'm sure jks is still so busy he can't see straight. is there a way to learn about the proxy service without having to email the fella?
