9Kkiwi
9Kkiwi
12
  • ok Thanx for the help mate ive sent the email for a new key, taking the kiwi and heading out to the new location i'll let you know what happens
  • ok gotcha i am about to change the ports now to 8074 restart the kiwi and request a new key via email move the kiwi to its new location and set the rest up from there Question, if for any unseen reason i have to have them share an antenna (via spli…
  • Hello Jks, "unique port number (typically 8074). So you would first make that change on the second Kiwi and restart" Are you referring to the internal/external port setting under the Network tab? "Does the first Kiwi use the prox…
  • Hello, In the next hour or so i will be relocating the Kiwisdr from current location to permanent location where it will be connected to a router which already has a kiwisdr connected to it and also it will have its own antenna connected. I'm worr…
  • Jks, thanx for your help, i am really pleased with the outcome and hopefully in the upcoming months will be looking at setting up a permanent kiwisdr at the radio club with a better antenna setup.
  • JKS, :) i believe it is working fine now and online on sdr.hu after i clicked the (re) register button thank you so much for your help guys
  • Jks, "" So try clicking the "click to (re)register" button again and see what you get"" Status:New account, registration successful sorry i just saw that part of your message and i clicked
  • Hello jks & Powernumpty, thanx for your responses... Jks "Status: Reverse proxy enabled and running" i have attached a screen shot with this post if you would like to have a look at the status. Also, the unique API Key was received …
