Matti65
Matti65
35
5
  • Connecting Kiwi via WiFi
    Today I was successful in getting my Vilros WiFI adapter to work with my KiwiSDR. I did the following:
    - Put in the dongle in the USB port of the Kiwi.
    - Use Putty to connect per SSH to my Kiwi (user=root; no pw)
    - Execute one by one the following commands:
    sudo apt-get install usbutils
    sudo apt-get install iw tools
    sudo apt-get install wireless-tools
    sudo apt-get install wpasupplicant
    sudo apt-get install wavemon
    - Then execute “lsusb” to get the name and the chipset of the adapter. I f.e. got the following result:
    Bus 001 Device 002: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    - If your chipset cannot be identified by this output, you should additionally look on this page to query for the chipset of your adapter:
    https://wikidevi.com/wiki/Special:RunQuery/Wireless_adapter_query
    - Then look in this list if there exists a linux driver for your chipset:
    https://wiki.debian.org/WiFi#USB_Devices
    - Go to the help page for your chipset. In my case it was “rtl819x”. There I found the hint, that I have to install the package “firmware-realtek”.
    - So I had to put in the command "apt-get install firmware-realtek" in Putty.
    - After completing the driver installation, send the command “lsmod” to see if the driver is installed. In my case the output was
    rtl8192cu 52250 0
    rtl_usb 8852 1 rtl8192cu
    rtl8192c_common 38293 1 rtl8192cu
    rtlwifi 54277 3 rtl_usb,rtl8192c_common,rtl8192cu
    So everything seemed to be fine.
    - Then put in the command “ifconfig -a” to see if the adapter is working. The output should have a “wlan0” section then.
    - Next you should encrypt your WiFI passphrase by using this command:
    wpa_passphrase „WiFi SSID“ „your ASCII passphrase” (without the “”)
    The resulting value for “psk” (not”#psk”!) is the encrypted passphrase. Memorize this for the next step.
    - Then you have to edit the file “interfaces” to configure your WiFi. Use this command: “sudo nano /etc/network/interfaces”
    - You have to add these lines here:
    auto lo
    iface lo inet loopback
    allow-hotplug wlan0
    auto wlan0
    iface wlan0 inet dhcp
    wpa-ssid "SSID" # without „“
    wpa-psk “your encrypted pw” # see above
    - Then Strg + O and Strg + X to save the file and quit the editor
    - Next you have to activate your WiFi once with the command "sudo ifup wlan0" and everything should be fine.
