Adding Kiwi to my website
Hi guys, recently purchased my first Kiwi SDR and have been configuring at today. After a bit of confusion between webpage and public, I managed to get all the information entered in the correct boxes and categories so that the front-end is displaying my information. However, what I am struggling with is how to add a link from my personal website to my Kiwi so that people going to my amateur radio website can simply click on a link and open up the page for my Kiwi.
I suspect it's probably under "connect". There are five options, the first domain name. At the moment, I've got public IP enabled. I did initially put in kiwisdr.g0vqy.co.uk but that didn't work.
Some help would be appreciated
Thanks
Penn
Thanks
Penn
https://g0vqy.co.uk/
This is slightly difficult to explain: On the admin panel the kiwisdr.com and sdr.hu entries will say "success" when the registration request that originates from your Kiwi reaches those sites with the proper data. But then kiwisdr.com and sdr.hu will both periodically poll your Kiwi to see if it is actually operating. If this polling fails then you will not be listed. Right now on kiwisdr.com I can see that your Kiwi initially registered, but subsequent polling has failed.
If your ISP blocks connection attempts that originate from the Internet (because they don't like the idea of you running a "server" on a residential connection paying residential rates) then you won't get listed and Internet users won't ever be able to connect to your Kiwi.
You need to use the Kiwi proxy service to get around this problem (setup info on the admin "connect" tab).
But this assumes BT isn't giving you a dynamic public ip address that will change at an arbitrary time in the future. If it is you'll have to do what Jim suggests and setup a DDNS to automatically update the A-record as needed.
[p.s. Sorry about the spurious rant about ISP blocking earlier. I'll blame it on lack of caffeine and my recent hassles with actual ISP blocking with another customer]
It is possible to run the Kiwi on port 80 so that the port doesn't have to be specified in the URL. But this may cause problems. For example since port 80 of your g0vqy.co.uk domain already points to your web server you couldn't also use port 80 of that domain for the Kiwi simultaneously. But of course this is not an issue for you currently since you are using a DDNS domain from noip (i.e. xxx.ddns.net).
