wsprdaemon and kiwirecorder
Hi All,
OK after resisting for as long as possible, I've now decided to try my luck with wsprdaemon and kiwirecorder.
As I'm not a Software, Python or Linux guy, this is going to be a bit of a learning curve for me.
Can anyone remind me where the code repositories are located ? I've tried searching through the forum and quick start guides and can't seem to find the links listed anywhere.
Also is there any (ideally step by step) documentation or a startup guide that I could use to get me going ?
but Rob and all need to explain broadly where things are found. I'm not at all sure the latest versions are here. Rob?
No no no, fishing is quite good fun I hear...
"I wouldn't bother Martin, I'm sure you wouldn't enjoy it, all those nasty spots you'd probably get and having to upload them and everything.."
Ha - well I'm already uploading a reasonable number, but it's the noise measuring part I'm really interested in.
Plus I'd like to see if it could be adapted for monitoring ALE network soundings.
Thanks for the email too :-)
Linux: http://ka7oei.blogspot.com/2018/10/a-quick-and-probably-incomplete-guide.html
Clint KA7OEI's blogspot installation instructions are for a much earlier version which required much more manual tweaking.
Still, installation and configuration requires some familiarity with Linux command line tools
I will add installation instructions on the github page.
