v1.674
From the CHANGE_LOG file:
v1.674 April 24, 2024
Antenna switch:
Antenna selection specified in the DX label extensions field now works correctly.
It is also possible to specify an antenna selection and an extension together, e.g.
"ant,1&wspr,30m" "FT8,*&ant=loop" etc. Just as you would in a URL.
"ant," and "ant=" are equivalent.
WSPR extension now uses the same mechanism to upload wsprnet.org spots as WSPR autorun.
This means the admin page, WSPR tab "Log spot debug info?" option works for both the extension
and auto run modes. Unfortunately wsprnet.org doesn't seem to be currently sending any spot
upload diagnostic information as it has done in the past.
Admin config tab:
RF attn slider is disabled for KiwiSDR 1 systems. This prevents the "Attn" annunciator from
incorrectly appearing in the S-meter.
Hi John, I tested my ms_s7_web switch under v1.673 and now v1.674 but couldn't get it to work.
I noted the new configuration possibility under 'Extensions' in the Admin interface,
filled in the IP address of the switch and ticked some boxes - but nothing happens.
Do I need to configure anything (backend etc.) through the console?
No antenna can be selected or deselected - mixing ant 1,3+7 occurs at random
Some screenshots attached.
Kai
I don't know why it isn't working for you, but just a few observations. For the NC antennas (presumably means 'Not Connected') just omit any description and the buttons won't display, leaving just the actual antennas. Having 5 antennas with the same descriptor could cause issues. Why have you got the option of 'High side injection' ticked for Antenna 1? That is for frequency converters.
Hi Kai,
I was not able to test with an actual ms-s7, so it's possible there's a bug in the backend script changes I had to make. Is it possible for me to connect as admin to your Kiwi? It would have to be Internet accessible. We can place it on the proxy service if necessary.
Please email details to support@kiwisdr.com
Thank you
Hi Barney, thanks for leaving a comment.
I deleted all the 'nc' entries and deselected 'high side injection'
but with no effect - ant 1,3+7 are still displayed as mixed.
I sent John a mail.
Kai
same problem here with kmtronics switch, no switching possible.
When i connect to the switch directly with browser, i'm able to access it and switch.
But from kiwiconsole unsuccesfull.
@on4iq It would be interesting to know if using the antenna switch scripts directly works or not.
Something like:
cda (change to dir /root/Beagle_SDR_GPS/pkgs/ant_switch)
abi (alias for "./ant-switch-frontend bi" printing the backend information)
as (get antenna status)
a1 (switch to antenna 1)
as
Hi ON4IQ,
also for my ms-s7, i can access it directly via the browser.
Let's see what evolves...
Kai
from console no switching possible
via webbrowser from PC i'm able to switch, but not from the kiwi.
Looks like kiwi frozen in G status (grounded i presume)
@on4iq Okay. If possible I would very much like to be able to connect to your Kiwi as admin and see if I can fix the problem. Please email details to support@kiwisdr.com Thank you.
ok mailed, and i cfm that the kiwi send G string to webswitch, just tried it
via webbrowser i actived the relay
via kiwi I selected an antenna and relays switch off
Thanks, checking now..
Thank you for your efforts !
Very happy to see the possibility to control antenna switching without having to open another window.
But I am missing the :
"reset-to-default-antennas-when-no-users-online"-script
Where I had all antennas grounded after a minute the last user left.
When I from the browser try to ground the antennas:
/?ext=ant_sw,g/
The logic is inversed and all antennas are switched in (mixing allowed)
the same if I try "tg"
I don´t now if it is firefox but i can not deselect an antenna i have to choose another also...
So there are some gremlins in the code yet ;-)
73:s de Kenneth / SM0OHC
Important information missing in the above post.
Which antenna switch device? None of the logic for grounding antennas was changed in any of the scripts. Does your antenna device ground any antenna that is not selected? Such that the correct action is to not select any antennas in the grounded condition?
The "reset-to-default-antennas-when-no-users-online" script was removed because there is an equivalent option in the admin interface now: The switch that says "Switch to default antenna when no users are connected?". With "Default antenna" checkboxes added to each of the antenna description entries below.
The problem with that of course is that there is no "Default antenna" option of "ground". So I need to add that. There is only the manual "Enable thunderstorm mode?" switch which does you no good in this case.
Thanks for reply !
I use the Arduino version, and the kiwi autoupdates, so now release v1.680.
A suggestion is to have "default antenna" ground when no user as a tickbox, as you said.
You can take a look at "ohc.zapto.org" how it behaves with the present settings:
Deny antenna mixing? NO
Deny multiuser switching? NO
Enable thunderstorm mode? NO
Switch to default antenna when no users connected? YES (no antenna ticked)
I can switch antennas but selected or unselected antenna is not indicated
If "Deny antenna mixing?" is set to YES I got a "green" but can´t unselect, and if another is selected that switches in ok but it does not unselect the previous and does not indicate that two antennas are:
And with that setting eventually all antennas is set no matter what you do.
73:s / K.
Good timing. Just moments ago I made that exact change: If none of the "Default antenna" checkboxes are ticked, and the "Switch to default antenna ..." is set to "Yes", then I now send the generic "ground all" command to the backend script. And the Arduino backend has an implementation for the "ground all" command. So hopefully it works.
Will be in the next release (v1.681). Probably going out in 12 hours or so.
