Saving current config via browser
Context: I'm connecting to a kiwi via a Pi 3B with a USB sound card attached. I am piping the audio out, to the audio in, and using QRSSPiG to demodulate the QRSS pictograms.
Status: This is all working ok.
Question: I am trying to capture the fussy level of settings needed for the demodulation to happen successfully. These include manual AF gain , manual RF gain and probably other things I haven't yet discovered
While I see that cookies store all the things I know I need so far (the above) I'd like to capture that in a URL and store a bookmark so that I can immediately return to the needed configuration. I know I can set AF gain (&vol=xxx) but I don't see manual/AGC settings in the example? Can I do this, and if so what is the syntax ? I don't see AGC/RF gain listed in the list of arguments you can pass via the URL.
Thanks for any help.
John
  • since you're already using linux in the RPi, you might consider using the kiwiclient tools rather than a browser. kiwi_nc.py, for example, give these options
    Usage: kiwi_nc.py [options]
    Options:
     -h, --help      show this help message and exit
     --log=LOG_LEVEL, --log-level=LOG_LEVEL, --log_level=LOG_LEVEL
                Log level: debug|info|warn(default)|error|critical
     --progress      Print progress messages instead of output of binary
                data
     -k SOCKET_TIMEOUT, --socket-timeout=SOCKET_TIMEOUT, --socket_timeout=SOCKET_TIMEOUT
                Timeout(sec) for sockets
     -s SERVER_HOST, --server-host=SERVER_HOST
                Server host (can be a comma-delimited list)
     -p SERVER_PORT, --server-port=SERVER_PORT
                Server port, default 8073 (can be a comma delimited
                list)
     --pw=PASSWORD, --password=PASSWORD
                Kiwi login password (if required, can be a comma
                delimited list)
     --tlimit-pw=TLIMIT_PASSWORD, --tlimit-password=TLIMIT_PASSWORD
                Connect time limit exemption password (if required,
                can be a comma-separated list)
     -u USER, --user=USER Kiwi connection user name
     --launch-delay=LAUNCH_DELAY, --launch_delay=LAUNCH_DELAY
                Delay (secs) in launching multiple connections
     -f FREQUENCY, --freq=FREQUENCY
                Frequency to tune to, in kHz (can be a comma-separated
                list). For sideband modes (lsb/lsn/usb/usn/cw/cwn)
                this is the carrier frequency. See --pbc option below.
     --pbc, --freq-pbc   For sideband modes (lsb/lsn/usb/usn/cw/cwn) interpret
                -f/--freq frequency as the passband center frequency.
     -m MODULATION, --modulation=MODULATION
                Modulation; one of am/amn, sam/sau/sal/sas/qam,
                lsb/lsn, usb/usn, cw/cwn, nbfm, iq (default passband
                if -L/-H not specified)
     --ncomp, --no_compression
                Don't use audio compression (IQ mode never uses
                compression)
     -L LP_CUT, --lp-cutoff=LP_CUT
                Low-pass cutoff frequency, in Hz
     -H HP_CUT, --hp-cutoff=HP_CUT
     --tlimit=TLIMIT, --time-limit=TLIMIT
                Record time limit in seconds
     -T THRESH, --squelch-threshold=THRESH
                Squelch threshold, in dB.
     --squelch-tail=SQUELCH_TAIL
                Time for which the squelch remains open after the
                signal is below threshold.
     -g AGC_GAIN, --agc-gain=AGC_GAIN
                AGC gain; if set, AGC is turned off (can be a comma-
                separated list)
     --agc-decay=AGC_DECAY
                AGC decay (msec); if set, AGC is turned on
     --agc-yaml=AGC_YAML_FILE
                AGC options provided in a YAML-formatted file
     --de-emp       Enable de-emphasis.
     --wf, --waterfall   Process waterfall data instead of audio
  • Hmmm. Something else I don't know how to do, but seems interesting. I'll do some searching on the forum to see how one uses kiwiclient. Being a Linux noob, everything is challenging, but the good news is I don't know what I don't know. :-)
    Thanks!
