XPloRR
Hello, I read your message just now here. Could you enter your serial number in QiwiQ? Sorry for the delay, Johan
XPloRR
315
25
  • QiwiQ a KiwiSDR client for Android: looking for feedback, testers and comments
    I understand what you mean, but the same field can also be used for a free Search field, so I cannot set both.
    KW5USA
    @dl7awl it is now possible to specify/select your private/local Kiwi server.
    dl7awl
    I understand your point. What I may consider is changing the swipe sensitivity. I could make it so the the full range can be reached in one swipe, without lifting your finger, but then I may loose resolution. I will do some checks, to see if all values of f.i. volume can be reached in one swipe. Could be that I have to change volume in steps of 5 or something. Will see what is the best tradeoff.
    Thank you for feedback!
    barneyuk
    Just now saw all these comments (i was talking in another thread with jks, will use this one now ;-))
    I am currently fixing a lot of problems, like the 2 connections will be 1 for all (wf, snd and ext).
    Fixing other problems like enter in the search screen.
    Also spend alot of work making the audio packets engine faster (should now be 35% faster).
    There is a bit more latency, but fewer packets should be dropped.
    Also reacting/closing sockets cleanly when connection cannot be made with server.
    Compiling now version 1.39. will test and release soon.
    Also working on DRM (can already decode using ext socket, but cannot assemble the audio, sounds like half the frequency, it seems the audio format is different in DRM mode).
    Will try to answer other questions asap, note that I am a newbie as far as shortwave is concerned, so I probably made mistakes interpreting what I read the last weeks (only been reading for 4 weeks about the ham/shortwave/amateur radio stuff)
    Nate_Rdl7awlN1NKM
    Hi all,
    I’ve been programming a mobile client for the KiwiSDR protocol, and I finally have something worth sharing: QiwiQ.
    It’s a dark-theme, portrait-mode KiwiSDR app for Android.
    Instead of running in the browser, my app processes the KiwiSDR stream locally on your phone.
    With no official KiwiSDR protocol documentation available, I relied on example Python code and reverse-engineered browser clients to piece together how the protocol operates.
    Features:
    • Connects to the public shared KiwiSDR network of servers.
    • Built-in waterfall FFT display with zoom and pan.
    • Direct band buttons for fast hopping between ham/shortwave bands.
    • Frequency logging and memory list.
    • Audio options: noise reduction, compressor, ADPCM compression.
    • Gestures for tuning: swipe digits, waterfall
    • Knobs for volume, squelch and filters.
    • Theme colors for the LCD display
    It’s still early days, but it’s working pretty well, I guess ;-).
    Download my QiwiQ.apk at: https://vanbarel.eu.org/tools/qiwiq/
    Side-load on Android, feedback/bugs very welcome!
    bwilsonstudentkraHB9TMCdl7awlF5AFYdreamsonNate_Rjolo22Tremolatva3xa
