HB9TMC
- HB9TMC
- 5,369
- 16
KIWI does not power on
You could check the other voltages:
Wonder what this is at 5300Khz? - its always there.
wifi connection and local time
@f6bir
The default gateway could be missing or wrong defined.
Can you show the output of "ifconfig" and "route"? -
Problem with massive RFI after changing router
@W9SPY
You could try using another power supply at the router (maybe the one from the old router). Just make sure it has the same voltage and polarity and an appropriate amperage rating.
Using a _non_ shielded ethernet cable may also help. (The BBG ethernet shield is connected to antenna ground. And some routers ethernet shields are connected to their PSUs minus pin) -
LED RFI
