jpe
jpe
93
4
  • Displaying sunrise and sunset times at your Kiwi QTH in your Kiwi UI
    If you wish to show the sunrise and sunset times at the location of your Kiwi SDR, please remove all code in the “Status” field under the “Webpage” tab in the Admin interface, and replace it with the following HTML code:
    In the example above, the “la” or the LATITUDE parameter in the URL is set to zero, as is the “lo” or the LONGITUDE parameter. You must set them to those of your QTH. Please note that southern latitudes are negative numbers as are western longitudes.
    The sunrise and sunset times are all in UTC, and can be found here:
    73 Jari OH6BG
    WA2ZKDrz3dvpG0LUJKK6PRKA7U
    73 Jari OH6BG
    73 Jari OH6BG
  • Advice on sharing RX antennas with 3 SDRs in the most effective way
    Thanks for all the comments, appreciated! In our case, we decided to use a simple T splitter to share the GPS signal with two Kiwis (the two Kiwis are powered by the same PSU). This setup worked for us, but your mileage may vary. Please read the comments from WA2ZKD before anything.
