G4DYA
- G4DYA
- 1,245
- 5
Opinions needed: Ham radio digital modes -- what's currently being used?
Pactor - no FOSS decoder AFAIK, but specification is open: https://www.p4dragon.com/downloads.html (under Documents).
FreeDV - little activity outside activity periods, but there seems to be quite a lot of interest. A UK-based group of FreeDV users has a 5 MHz weekly net and at least one of them uses my Kiwi to check his signal. https://freedv.org/ https://qso.freedv.org/
Digital SSTV - aka HamDRM among other names - I use QSSTV to decode this. It's Qt-based, cross-platform and GPL 3. https://github.com/ON4QZ/QSSTV
Flatness of KiwiSDR response < 500 kHz?
Feature Request
Combining/Diplexing Antennas to Single Kiwi
I'm using a diplexer to combine a Wellbrook loop with a 27m horizontal terminated folded dipole (TFD). The crossover frequency is about 1.7 MHz. (I found the TFD marginally better on 1.8 MHz.) The TFD has notches for the 4, 6 and 7 MHz broadcast bands. This feeds an Elad ASA16 distribution amplifier which feeds the Kiwis.
When doing TDoA, I often find that Martin's RX is the only other one in the UK that can hear what I'm hearing. (It's 50/50 which is best.)
The main factor affecting performance is neighbour QRM which varies enormously.
http://kiwisdr.lamont.me.uk:8073/
I attempted to upload a circuit diagram and a photo, but lost my fight with this forum's software and gave up.
Richard -
The BB version seems to be over-riding the Kiwi's network settings at boot and using DHCP regardless of whether it's configured for DHCP or static. If you're using a non-NATted static IP this can be very confusing.
To get a static IP, it's necessary to use connmanctl:
Find a filename in /var/lib/connman/ starting with "ethernet", e.g ethernet_01234567890ab_cable, then as root:
connmanctl config ethernet_01234567890ab_cable --ipv4 manual ip_address netmask gateway_ip
Then add the IP addresses for a couple of your ISP's nameservers:
connmanctl config ethernet_01234567890abcdef_cable --nameservers 8.8.8.8 4.4.4.4
