5,458
29
  • wifi on BBG (MT7601)
    Easiest route is probably something like the TP-Link nano routers (E.G. Tl-wr802n), powered from 5V.
    It connects to the Kiwi/BB via ethernet cable.
    That set up is good because it offers more placement options for best WiFi link.
    I have used that one and it was easy to set up as the Kiwi is treated just like any other wired device connected to the nano router.
    WA2ZKDG0LUJ
  • Audio queue depth slowly drops to zero, then resets, causing audio underrun - 8 receiver mode
    Are you running external WSPR decode (with a recorder.py etc.) or the WSPR extension? running external decoding would be a better move in this setup I believe.
    WV5L
    The extension is simple but there are benefits to using the external decodes, the detection rate is higher by default.
    WV5L
    WA2ZKDG0LUJ
  • PSU - identify the 34p one
    I'm sure there are many older supplies designed when compliance was "a thing", I've got a few that seem pretty good but I'm keen to find resonable current options for those people without decent "junk" reserves ;-).
    I hadn't tried these tiny PCB's simply as I had assumed the noise would be too intrusive but a comment on here prompted me to look. Linear supplies are getting harder to find more so considering switchers are often listed a "linear" now. In fact I'm getting annoyed with the amount of fake carp on Ebay, can't trust many listings now around power supplies, I still look for older stuff with full traceable approvals.
    elitedata
