rrobinet
- rrobinet
- 1,324
- 9
use of kiwirecorder, kiwiwspr etc
I have just finished version 0.5d which adds support for a watchdog and scheduled band configuration changes.
It also incorporates many command line changes which I hope make it easier to use.
However it requires changes to the CAPTURE_JOBS[] array in the kwiconfig.conf file and you must add at least one WSPR_SCHEDULE[] entry.
It is running well at 3 sites, but as always save your current kwiwspr.sh and kwiwspr.conf file in case this new version doesn't work for you.
It is a very lightweight program and you can easily spot all 14 LF/MF/HF WSPR bands on a Raspberry Pi
I welcome comments and bug reports -
The Kiwi runs an update task once a day to check for a new SW version and as part of that process terminates autowspr and kiwirecorder.py sessions for reasons only known to John. So that is one more reason for the need for a watchdog. My enhanced version with scheduled band changes is almost ready for testing -
What is the status of the WSPR background and autostart features? [added in v1.181]
I didn't know there was any activity on 60M, but of course I'll add it.
I too want to mmimic the "band Hopping' feature of WSJT-x. I won't have time to work on it for a few days.
In the mean time, you could create a set of kiwiwspr.conf files and have the cron job run "-J z; mv replace kiwiwspr.conf; -J a"
