rrobinet
I have configured several Kiwis for wifi access by attaching an inexpensive router configured as a Wifi client to the ethernet port of the Kiwi. This $25 TP Link has worked well for me: https://smile.amazon.com/TP-Link-Wireless-Portable-Travel-Router/dp/B00TQEX8BO/ref=sr_1_14?keywords=tplink+wifi+router&qid=1548188019&sr=8-14 In principle one could enable the internal BB Wifi or attach a USB wifi adapter, but I am reluctant to fiddle with the Kiwi's OS.
rrobinet
1,325
9
  • wsprdaemon - A Raspberry Pi WSPR decoding service
    I have just checked in V2.6b to https://github.com/rrobinett/wsprdaemon where you will find installation and upgrade instructions.
    Among other improvements, this version addresses an upload problem which may be causing WD users to pound the wsprnet.org database.
    So I strongly encourage existing user to upgrade to V2.6b
    PowernumptyG8JNJHB9TMC
    I have been watching the WD upload log and see many, many timeouts on upload attempts to wsprnet.org.
    WD caches it spots until a successful upload so when wsprnet.org goes offline for 10 minutes or more WD can be caching 100 or more spots.
    wsprnet.org seems to reject uploads of 100+ spots (I'm not sure what is that limit, so that is a guess). At that point WD gets into a continuous upload failure loop while its cache of spots grows larger and large.
    I am going to add a limit of upload size to WD 2.6b to try to address this problem.
    But the larger problem is the frailty of wsprnet.org.
    I maintain a research grade database of noise data at wsprdeamon.org and I am thinking I will add a spots database as well.
    WD users will be able to make real queries of their spot data and create graphs from queries.
    PowernumptyG0LUJ
    PowernumptyG0LUJ
    Hi Clint,
    wsprnet.org is the source of ZKD and AMG lists, so if your spots were in wsprnet.org but not ZKD/AMG, then the problem was not in WD.
    There is a seperate flow of data and files to create the WD logs and graphs, so uploads could fail while graphs appear.
    So I have no explanation for your extended disappearance. There are some WD log files which could potentially grow to fill the /tmp/wspr-captures file system, but without access to your PC while in a failure state I can't really diagnose the cause.
    Your GPS was diagnosed and fixed by JKS v1.335. In a busy 8 channel mode the Kiwi was not searching for new satellites. I encounters your GPS problem at KPH during WD v2.6 development and can certify that the problem has been fixed.
    I have posted a late apha version of WD2.6 in github: https://github.com/rrobinett/wsprdaemon/tree/rrobinett-v26
    Logging of overload events is one new feature you might find useful.
    G0LUJrz3dvp
    Hi Clint,
    G0LUJrz3dvp
