16,165
14
  • Measuring the AM Modulation in the AM and AMN Mode
    Jimo
  • Alternate cooling method
    Almost ready... removed paper ducts and with 4X 14 ch installed max temp at 100% CPU is 44 deg C, a 19C rise
    KA7UPowernumpty
    KA7UPowernumpty
    The evolving kiwi cluster
    PowernumptyKA7UG0LUJ
  • rx.linkfanel.net receiver map moving to Leaflet
    Relative to that topic, is there any how-to, guide or documentation anywhere to improving and tuning reception quality on your KiwiSDR?
    I do not think there is anything in one spot. There are many excellent posts here in this forum. Here's a summary of my experiences:
    • Have a reasonably good antenna and keep it away from known RFI sources.
    • Be conscious of things like MW BC overload and apply filters as required
    • Avoid switching PSU, some are quiet but most are not so try to use linear PSU
    • Understand Common Mode Interference, read up on it, applies the easy remedies like use of ferrite core and intermediate grounding on your feedline
    • Watch for spurious using the [SPEC] display on a KiwiSDR client webpage, much noise can be noted by "lumps" of noise or spurs carriers at repeating spacing across a band
    • ID noise spurious by turning things on/off within your dwelling ot near the antenna
    • a partial list...
    G0LUJKA7UG8JNJ
