- WA2ZKD
- 16,165
- 14
Audio Loopback
I wonder if an extension could be written to loopback the audio. Maybe using something fromIt could eliminate using a VAC for external decoders... -
java on BBG
java on BBG
Use CAT6 shielded communications cable for antenna feedline, rotor control, and LNA power
a look at page 2 here shows the screw terminals are not balanced -
Home Brew Broadband Magnetic Loop
Related stuff here. I imagine the low end of that balun doesn't do well at LW but the board could be the base for alternate toroids
