16,165
14
  • Grove Project
    I have the Grove stuff working.... I just installed the latest debian stretch release. Obviously, as it needs stretch, my work so far has been on a bare BBG, not a kiwi
  • GPS antenna trick
    Ron, look at the Degen/Kaito MS-31 type loop
  • How many WSPR decoders can be run without affecting performance?
    I would suggest you use Rob's 2nd computer scheme. It was kiwiwspr.sh but now wsprdaemon.sh. It will service all kiwi channels without any issues.
    alain_
  • Noise at roughly 60 KHz intervals
    I note that the high-quality shielded Cat cables have the drain wire tack soldered to the metal clip at the plug. Sadly, I have also found that "professional" installers often do not even deal with the drain wire on installations in businesses.
  • Kiwirecorder 101
    Perhaps this helps
    Usage: kiwirecorder.py [options]
    Options:
    -h, --help show this help message and exit
    --log-level=LOG_LEVEL, --log_level=LOG_LEVEL
    Log level: debug|info|warn|error|critical
    -q, --quiet Don't print progress messages
    -k SOCKET_TIMEOUT, --socket-timeout=SOCKET_TIMEOUT, --socket_timeout=SOCKET_TIMEOUT
    Timeout(sec) for sockets
    -s SERVER_HOST, --server-host=SERVER_HOST
    Server host (can be a comma-delimited list)
    -p SERVER_PORT, --server-port=SERVER_PORT
    Server port, default 8073 (can be a comma delimited
    list)
    --pw=PASSWORD, --password=PASSWORD
    Kiwi login password (if required, can be a comma
    delimited list)
    -u USER, --user=USER Kiwi connection user name
    --launch-delay=LAUNCH_DELAY, --launch_delay=LAUNCH_DELAY
    Delay (secs) in launching multiple connections
    -f FREQUENCY, --freq=FREQUENCY
    Frequency to tune to, in kHz (can be a comma-separated
    list)
    -m MODULATION, --modulation=MODULATION
    Modulation; one of am, lsb, usb, cw, nbfm, iq
    --ncomp, --no_compression
    Don't use audio compression
    --dt-sec=DT Start a new file when mod(sec_of_day,dt) == 0
    -L LP_CUT, --lp-cutoff=LP_CUT
    Low-pass cutoff frequency, in Hz
    -H HP_CUT, --hp-cutoff=HP_CUT
    --fn=FILENAME, --filename=FILENAME
    Use fixed filename instead of generated filenames
    (optional station ID(s) will apply)
    --station=STATION Station ID to be appended (can be a comma-separated
    list)
    -d DIR, --dir=DIR Optional destination directory for files
    -w, --kiwi-wav Use wav file format including KIWI header (GPS time-
    stamps) only for IQ mode
    --kiwi-tdoa Used when called by Kiwi TDoA extension
    --tlimit=TLIMIT, --time-limit=TLIMIT
    Record time limit in seconds
    -T THRESH, --threshold=THRESH
    Squelch threshold, in dB.
    -g AGC_GAIN, --agc-gain=AGC_GAIN
    AGC gain; if set, AGC is turned off (can be a comma-
    separated list)
    -z ZOOM, --zoom=ZOOM Zoom level 0-14
    --wf Process waterfall data instead of audio
    --snd Also process sound data when in waterfall mode
    M0TAZ
