15,911
12
  • How many WSPR decoders can be run without affecting performance?
    I would suggest you use Rob's 2nd computer scheme. It was kiwiwspr.sh but now wsprdaemon.sh. It will service all kiwi channels without any issues.
    alain_
  • Noise at roughly 60 KHz intervals
    I note that the high-quality shielded Cat cables have the drain wire tack soldered to the metal clip at the plug. Sadly, I have also found that "professional" installers often do not even deal with the drain wire on installations in businesses.
  • Kiwirecorder 101
    Perhaps this helps
    Usage: kiwirecorder.py [options]
    Options:
    -h, --help show this help message and exit
    --log-level=LOG_LEVEL, --log_level=LOG_LEVEL
    Log level: debug|info|warn|error|critical
    -q, --quiet Don't print progress messages
    -k SOCKET_TIMEOUT, --socket-timeout=SOCKET_TIMEOUT, --socket_timeout=SOCKET_TIMEOUT
    Timeout(sec) for sockets
    -s SERVER_HOST, --server-host=SERVER_HOST
    Server host (can be a comma-delimited list)
    -p SERVER_PORT, --server-port=SERVER_PORT
    Server port, default 8073 (can be a comma delimited
    list)
    --pw=PASSWORD, --password=PASSWORD
    Kiwi login password (if required, can be a comma
    delimited list)
    -u USER, --user=USER Kiwi connection user name
    --launch-delay=LAUNCH_DELAY, --launch_delay=LAUNCH_DELAY
    Delay (secs) in launching multiple connections
    -f FREQUENCY, --freq=FREQUENCY
    Frequency to tune to, in kHz (can be a comma-separated
    list)
    -m MODULATION, --modulation=MODULATION
    Modulation; one of am, lsb, usb, cw, nbfm, iq
    --ncomp, --no_compression
    Don't use audio compression
    --dt-sec=DT Start a new file when mod(sec_of_day,dt) == 0
    -L LP_CUT, --lp-cutoff=LP_CUT
    Low-pass cutoff frequency, in Hz
    -H HP_CUT, --hp-cutoff=HP_CUT
    --fn=FILENAME, --filename=FILENAME
    Use fixed filename instead of generated filenames
    (optional station ID(s) will apply)
    --station=STATION Station ID to be appended (can be a comma-separated
    list)
    -d DIR, --dir=DIR Optional destination directory for files
    -w, --kiwi-wav Use wav file format including KIWI header (GPS time-
    stamps) only for IQ mode
    --kiwi-tdoa Used when called by Kiwi TDoA extension
    --tlimit=TLIMIT, --time-limit=TLIMIT
    Record time limit in seconds
    -T THRESH, --threshold=THRESH
    Squelch threshold, in dB.
    -g AGC_GAIN, --agc-gain=AGC_GAIN
    AGC gain; if set, AGC is turned off (can be a comma-
    separated list)
    -z ZOOM, --zoom=ZOOM Zoom level 0-14
    --wf Process waterfall data instead of audio
    --snd Also process sound data when in waterfall mode
    M0TAZ
  • Ionosonde
    If you do a full freq look at the Kiwi WF you can often see the chirp sweep go by. I'd like to be able to pick a chirp TX site by name name, Millstone Hill for example, and knowing it's start time, be abe to ID that sweep that goes by. The highest freq seen would indicate the MUF for it at the Kiwi RX site.
  • New Station in Maine
    it is now http://rx2.wa2zkd.net and is on sdr.hu as well
