SWLJO43
Yeah, the new one is extremly faster, than you John.A single WSPR new decoder is running and running.After starting a second WSPR new decoder, without anything to decode, it is runing and running.After starting a third WSPR new decoder, the KiwiSDR is resetting after arround 30 minutes. :-(
If i repeat the steps mentioned above, this error occurs every time.
- SWLJO43
- 83
- 25
Um? unknown halloween signal
8 channel Kiwi WSPR decoding script 'kiwiwspr.sh' using Raspberry Pi or other external server
Hello,
in my case i use an older Computer and i installed
- debian-9.5.0-amd64-netinst
- dpkg -i wsjtx_1.9.1_amd64.deb
- apt-get install bc
- apt-get install ntp
- apt-get install python-numpy
- apt-get install curl
and your kiwiwspr.sh to /home/pi/kiwiwspr
and the kiwirecorder.py to /home/pi/kiwiwspr/kiwiclient-jks-v0.1
To configure in my case: nano /home/pi/kiwiwspr/kiwiwspr.conf
Now i use 6 Channels on my "http://jnlb0dg4phlqpnun.myfritz.net:8074" without problems.
Thanks Dirk (SWLJO43) -
TDoA Successes
External Programs, what do you use
Hi,i am using.ALE_32 -> MIL-STD 188DREAM211 -> DRMEasyPal -> DigiSSTVfldigi -> RTTY, CW,...MMSSTV -> SSTVRXSSTV -> SSTVMUTLIPSK -> RTTY, CW, SSTV, DGPS, ...NAVTEX -> NavtexOpera 1.6.5 -> Opera ELF, VLFPC-HFDL 2.042 -> HFDLSoDiRa -> 77.5 khz Clocksorcerer 1.0.1 -> STANAG, EFR, DGPS, ...WSJT-X -> WSPR, FT8, JT65,... (PSKREPORTER)KiwiSDR -> WSPRUISS 5.4 with SoundModem UZ7HO -> AFSKcu Dirk
