SWLJO43
Yeah, the new one is extremly faster, than you John.A single WSPR new decoder is running and running.After starting a second WSPR new decoder, without anything to decode, it is runing and running.After starting a third WSPR new decoder, the KiwiSDR is resetting after arround 30 minutes. :-(
If i repeat the steps mentioned above, this error occurs every time.
- SWLJO43
- 83
- 25
Good DRM Decodes - China Radio Int - 13850KHz
Um? unknown halloween signal
8 channel Kiwi WSPR decoding script 'kiwiwspr.sh' using Raspberry Pi or other external server
Hello,
in my case i use an older Computer and i installed
- debian-9.5.0-amd64-netinst
- dpkg -i wsjtx_1.9.1_amd64.deb
- apt-get install bc
- apt-get install ntp
- apt-get install python-numpy
- apt-get install curl
and your kiwiwspr.sh to /home/pi/kiwiwspr
and the kiwirecorder.py to /home/pi/kiwiwspr/kiwiclient-jks-v0.1
To configure in my case: nano /home/pi/kiwiwspr/kiwiwspr.conf
Now i use 6 Channels on my "http://jnlb0dg4phlqpnun.myfritz.net:8074" without problems.
Thanks Dirk (SWLJO43) -
Hello,
TDoA Successes
