- jks
- 36,721
- 670
Vote rigging on sdr.hu
V1.107 - Daily restart [restart after update also added]
Minimum CW bandwidth needs reducing [fixed: min is now 4 Hz]
v1.107 will let you reduce it to 4 Hz. At this low of a value the filter skirts aren't so great as a percentage of the passband width. But there is a definite signal-to-noise improvement over the previous 50 Hz minimum, so this was a worthwhile change.Remember the shortcut of holding down the shift key and click on the zoom in/out icons (+/- magnifying glasses) to easily change the passband width by +/- 80%. -
NOAA FAX
Yes, the v1.100 release improved the situation. Details here: https://github.com/jks-prv/Beagle_SDR_GPS/commit/ba3ec102465bfe29d8a6582cb4068ba4c8dbe700 -
does ipv6 prevent registration? [fixed in v1.100]
Looks like my fix in v1.100 worked. You're now listed on sdr.huI added the "--inet4-only" option to the wget that sends the registration info to sdr.hu That way it won't get an ipv6 packet and fail to match with the domain ip.Thanks, I didn't realize there were such things as ipv6 tunnels. I'll give it a try.
