- jks
- 36,739
- 670
Some things I have noticed [problems with a large DX/label database]
Is there an issue with the inactivity time limit? [fixed in v1.165]
Okay, bug has been found and will be fixed in today's update. A very unfortunate side-effect of an unrelated change made some time ago.Note when testing: as a convenience, connections from your local network are exempt from the inactivity and 24-hour timeouts. Look for a log message like "TLIMIT exempt local connection from 192.168.1.8". Same if you have given the exemption password with a local browser and it has been stored in a cookie. -
v1.161: FSK/RTTY extension
Ethernet interface unreliable - very serious problem [fixed with better power supply cable]
