- jks
- 36,738
- 670
What is the status of the WSPR background and autostart features? [added in v1.181]
@Glenn: It's a bug. Being fixed in today's update. -
kiwid restarts after assertion failure in support/coroutines.cpp [fixed in v1.184]
No, that shouldn't be related. There was definitely a bug in the task lock code for a special case. It's just that the case only ever occurs when the GPS acquisition is enabled or disabled as users make SDR connections. I was able to trigger the bug on my own Kiwi by artificially increasing the rate of occurrence of the special case. -
GPS: Galileo reception possible on Kiwi? [working as of v1.178]
v1.177 is out with Galileo support. Not perfect, but good enough for some widespread testing.On the admin GPS tab the switch labeled "Plot Galileo?" determines if separate position solutions including Galileo, and not, are computed and displayed. But note that this only works if there are at least 4 sats of each category present (i.e. 4 Galileo, 4 Navstar/QZSS). On the new "Map" display different color pins will be used to show the differences. See the legend at the bottom of the map.Sometimes when Galileo sats are used the positions don't agree with Navstar/QZSS (i.e. the green and red/yellow pins will be spaced some distance apart). This may be due to the well known false-peak locking issue with the Galileo waveform. We are still implementing a solution for this issue.
