36,751
670
  • v1.290/291/292 software updates
    From the CHANGE_LOG file:
    v1.290  June 12, 2019
        UI changes for devices with small screens: (phones or tablets)
            Clicking control panel navbar "Off" icon repeatedly will toggle the top bar visibilities.
                Similar to how 'y' shortcut key functions with desktop browsers.
            For narrow phone-width screens the control panel is scaled to fit the screen width
                if the phone is being held in "portrait" orientation when connecting to the Kiwi.
        Support for "masked" frequencies where the audio is muted and the waterfall blanked.
            Designed to help deter users who camp on particular frequencies for long periods of time.
            As admin create DX label(s) with a type value of "masked". When any part of the current
            passband crosses into the masked area the audio is muted. The mode of the label determines
            the width of the masked/blanked area (as seen on the waterfall). Custom label passbands apply
            so you can precisely control which frequencies are masked.
        S-meter extension now has selectable averaging. Previously, when the measurement speed
            speed was low, the multiple S-meter samples were plotted along the same x-axis position.
            Also, the speed slider now selects an inverse power of two samples (was linear).
            The maximum measurement interval (1/4096) is now roughly 1.5 minutes.
        Support for cloning Kiwi configuration files from another running Kiwi. See new user interface
            on the admin config tab. This is intended for owners of multiple Kiwis (yes they exist!)
            that want an easy way to replicate an existing configuration before further customization.
            All of the relevant files in /root/kiwi.config are cloned including kiwi.json, admin.json,
            dx.json and config.js (band definitions). Option to clone only the dx.json file.
        Better trackpad/mouse-wheel waterfall zoom behavior.
            Previously the trackpad response was too sensitive causing the zoom to go full max/min
            instantly for a small trackpad movement even though a mouse wheel worked reasonably.
        Proxy support for variable port number.
            Previously only one Kiwi could be proxied per public ip address.
            Now multiple Kiwis with different local port numbers can use the proxy service behind
            a router with a single public ip/global-port. The Kiwis are differentiated by their
            host names on the proxy. E.g. mykiwi1.proxy.kiwisdr.com:8073/ and
            mykiwi2.proxy.kiwisdr.com:8073/ (note both port 8073) where mykiwi1 could be on
            local network port 8073 and mykiwi2 on local port 8074.
    KA7UPowernumptyG8JNJChrisSmolinskiHB9TMC
  • Frequency Blacklist [fixed in v1.290]
    I've resisted doing this for a long time because I don't like the idea.
    But there have been many requests now and I got something working with only a day's worth of work. It will be in the next release.
    PowernumptyChrisSmolinskiWA2ZKD
  • S meter averaging? [fixed in v1.290]
    Okay, this was relatively easy and will be in the next release.
    PowernumptyHB9TMC
  • KIWISDR.LOCAL only working on admin interface
    One additional thing to check. If you can, log into the Kiwi Beagle and type "scs avahi-daemon". See if it is running. If it's not running then restart it by typing "scre avahi-daemon", check the status again with "scs", and see if pings to kiwisdr.local begin to work. Also check that "cat /etc/hostname" on the Beagle prints "kiwisdr" as the host name.
