36,755
670
  • S meter extension - prevent clearing? [fixed in v1.318]
    v1.318  August 27, 2019
        FAX extension:
            Add LPM (lines per minute) selection. Automatically set 60 LPM for JJC/JSC
            Frequency list corrections; added XSG Shanghai; removed BMF Taipei
        S-meter extension:
            Don't clear graph on frequency change. Instead draw vertical division marker: red when
            frequency change, green when mode change.
        Better detection of missing audio panner API on some browsers.
    PowernumptyHB9TMCChrisSmolinskibensonG8JNJ
        FAX extension:
        S-meter extension:
  • W/F and SND Bad Params
    I'll have an automatic solution built-in to the Kiwi software after I return.
    The little bit of decoding I've done is really inexplicable. I can see the beginnings of what they're trying to do. But it's incomplete and the end result is that absolutely nothing of value is gained. Except for adding a bunch of log messages and causing general annoyance.
  • Kiwi WebSDR kind of stuck at 1.289 - update found... nothing happens... [apt problems, manual fix]
    I fixed the build manually.
  • TDoA background maps not loading
    Later today (hopefully) we will switch back to our previous map provider and the newer TDoA user interface.
    We have decided to purchase a commercial subscription, at considerable cost, from the map provider in the interest of expediency. Like the costs to run the proxy service it will be absorbed by KiwiSDR and not passed along to the customer.
