36,764
673
  • Connecting Kiwi via WiFi
    Update to v1.311, then login to the Beagle as root and do the following:
    cdp
    mst
    cdk
    nano admin.json [or other text editor of your choice]
    [go to end of file and replace "options":0 with "options":1]
    [save changes]
    cdp
    ku
    [wait 1 minute]
    ms
    Now look for these messages in the log where "eth0" is hopefully replaced with your USB WiFi's identifier. The last two lines should have the local network address of the WiFi interface. Connecting to the admin page should now work.
    Sep 12 00:55:28 www kiwid[1551]: 00:00:32.181 ...     getifaddrs: IF lo fam=17 flags=0x10049 UP RUNNING
    Sep 12 00:55:28 www kiwid[1551]: 00:00:32.188 ...     getifaddrs: IF eth0 fam=17 flags=0x19043 UP RUNNING
    Sep 12 00:55:28 www kiwid[1551]: 00:00:32.191 ...     getifaddrs: IF usb0 fam=17 flags=0x1003 UP
    Sep 12 00:55:28 www kiwid[1551]: 00:00:32.193 ...     getifaddrs: IF lo fam=2 flags=0x10049 UP RUNNING
    Sep 12 00:55:28 www kiwid[1551]: 00:00:32.193 ...     getifaddrs: IF eth0 fam=2 flags=0x19043 UP RUNNING
    Sep 12 00:55:28 www kiwid[1551]: 00:00:32.193 ...     getifaddrs: CHECK eth0 fam=2
    Sep 12 00:55:28 www kiwid[1551]: 00:00:32.194 ...     DDNS: IF IPv4 0xc0a80167 /24 0xffffff00 eth0
    Sep 12 00:55:28 www kiwid[1551]: 00:00:32.194 ...     getifaddrs: IF usb0 fam=2 flags=0x1003 UP
    Sep 12 00:55:28 www kiwid[1551]: 00:00:32.194 ...     getifaddrs: IF lo fam=10 flags=0x10049 UP RUNNING
    Sep 12 00:55:28 www kiwid[1551]: 00:00:32.194 ...     getifaddrs: IF eth0 fam=10 flags=0x19043 UP RUNNING
    Sep 12 00:55:28 www kiwid[1551]: 00:00:32.194 ...     getifaddrs: CHECK eth0 fam=10
    Sep 12 00:55:28 www kiwid[1551]: 00:00:32.194 ...     DDNS: IF IPv6 LINK-LOCAL /64 eth0
    Sep 12 00:55:28 www kiwid[1551]: 00:00:32.194 ...     DDNS: private IPv4 <192.168.1.103> 0xc0a80167 /24 0xffffff00 eth0
    Sep 12 00:55:28 www kiwid[1551]: 00:00:32.194 ...     DDNS: private IPv6 LINK-LOCAL  /64 ff:ff:ff:ff:ff:ff:ff:ff:00:00:00:00:00:00:00:00: eth0
    HB9TMC
  • Find your Kiwi using my.kiwisdr.com
    This feature has not been tested with IPv6 or mixed IPv4/IPv6 local networks. So there is likely some debugging required.
    rz3dvpJimoJIsenhart
  • Locked out by using the Admin page?
    All there is at the moment is the user/admin guide ("operating information", which grew from the "quick start" page) http://kiwisdr.com/quickstart/index.html Even that is unfortunately incomplete (some commands and options are not documented).
    There is a architecture design document, but it is very old and somewhat out-of-date: https://www.dropbox.com/s/i1bjyp1acghnc16/KiwiSDR.design.review.pdf?dl=1
    There is no "tour" guide of the software/files. That was always a low-priority task. Sadly we don't have many software contributors, although the ones we do have are doing some absolutely stellar work. And of course our many forum contributors are providing a great service to our user base.
    Hajo
  • S meter extension - prevent clearing? [fixed in v1.318]
    Will be in today's v1.320:
    	marker_s:      [ '1 sec', '5 sec', '10 sec', '15 sec', '30 sec', '1 min', '5 min', '10 min', '15 min', '30 min', '1 hr' ],
    G0LUJHB9TMCG8JNJChrisSmolinski
