36,248
639
  • KYOTO News FAX 16969.1 kHz 23:00utc
    In v1.318/319 there is support for multiple LPM settings. And the preset for JJC/JSC now selects 60 LPM and was tested (see below). XSG now replaces BMF. And JFC/JFW/JFX has been added per mt-utility.blogspot.com/2010/02/1800-utc-8658-utc-fax-confirmed-jfx.html (I had a successful reception on 16907.5) The frequency for HSW64 was fixed.
    A speculative entry was added for GM-11F Ukraine (see: mt-utility.blogspot.com/2009/12/so-who-is-gm-11f.html)
    That post is 10 years old. Since 1430Z is 0230 am for me could someone try listening at that time and see if GM-11F is still on the air?
  • S meter extension - prevent clearing? [fixed in v1.318]
    Will be in today's v1.320:
    	marker_s:      [ '1 sec', '5 sec', '10 sec', '15 sec', '30 sec', '1 min', '5 min', '10 min', '15 min', '30 min', '1 hr' ],
    G0LUJHB9TMCG8JNJChrisSmolinski
    v1.319  August 28, 2019
        Fixed bug in audio FFT mode. If you visited a new Kiwi for which no FFT WF max/min cookie
            values had ever been stored you'd always get a black waterfall until clicking "Auto Scale"
            and then reloading the page.
        FAX extension:
            Now has a 2k line scroll-back buffer.
            Added phasing and autostop capabilities. Phasing will automatically align (shift) the image
            horizontally if the phasing signal at the beginning of the transmission is clear enough.
            Autostop will stop the image buffer updating if the fax start/stop tones are clear enough.
        S-meter extension:
            Now has stop/start and "mark" buttons.
    The phasing feature seems to work okay the first time (after extension start up) but after that it only works occasionally. So there is more work to be done.
    bensonPowernumptyG8JNJ
        FAX extension:
        S-meter extension:
