- jks
- 36,244
- 639
v1.360+: DRM extension now available
Low FPS on the latest versions.
So things got worse beginning with v1.337. I found one reason and have fixed that for today's v1.359 release. But there is still a performance problem I don't understand. v1.337 was a complex release with waterfall averaging and a lot of BBAI-related changes.
I haven't looked at it, but it is possible the denoiser and auto-notch can be moved from the Beagle to Javascript running on the browser. Assuming the browser is running on a decent device (desktop pc or recent mobile device) the performance should be sufficient to support it. -
new ADC overflow logic (S-meter "OV" indicator) [added in v1.315, improved in v1.357,358]
Alright, v1.357 is out with an S-meter OV averaging adjustment slider on the admin config tab.
Remember that the averaging is defined as as threshold count of per-sample ADC overflow events for every 64k ADC samples. So when the slider is set to 1k (the default) it means that the OV indicator will only light if there have been >= 1k ADV OVs during the 64k period. Note that the 1k OV events don't have to be consecutive. It's a threshold over a fixed interval. -
