36,232
639
  • v1.390: cross compilation, SAM demodulators
    From the "I'm not working on it except when it interests me" department:
    v1.390  April 23, 2020
        Performance improvements:
            Suggested by @howardsu on Kiwi forum: remove -DDEBUG so assert()'s are not evaluated.
            	Added new "make debug" target to revert to compiling with -DDEBUG defined.
            Christoph's cross-compilation changes: added "make xc" target that allows cross-compiling on
                development host. Alternative to slow compiles on Beagle during development.
                See file CROSS_COMPILE for complete details.
        Added synchronous AM (SAM) demodulators from Warren Pratt's wdsp package via the
            Teensy-ConvolutionSDR implementation: github.com/DD4WH/Teensy-ConvolutionSDR
            See the Kiwi operation manual for more information: kiwisdr.com/quickstart/index.html#id-faq-sam
            Synchronous AM modes: SAM, SAL, SAU, SAS
        User interface changes:
            Use keyboard shortcut 'A' to toggle the SAM modes (sorry, 's' and 'S' were taken).
                As always type 'h' or '?' to see the list of all keyboard shortcuts.
            Bugfix: Adjusting the passband via a "/width" or "/low,high" entry in the
                frequency box is now "sticky" i.e. remembered when returning to the mode.
                Just like when changing the passband via the 'p' and 'P' keyboard shortcuts.
                Restore as usual by shift-clicking on the mode button.
    I'm interested in feedback about the SAM demods from the BCB DX crowd. But remember that this code is just lifted from wdsp and I don't know much about it. There are some tunable PLL parameters that could potentially be optimized. Please read the Kiwi operation manual for full details: kiwisdr.com/quickstart/index.html#id-faq-sam
    ZygbensonPowernumptyG0LUJjpeLX1DQ
  • Rounded Frequency Set
    Found it. Only happens on Kiwis with ITU region set to 2! (Americas) Has to do with the recently added code to force 1 kHz stepping in the 75/80m ham/BCB overlap segment for region 2 (change made in response to a user request) :/ Will be fixed in the next release.
    Zyg
