- jks
- 36,764
- 673
v1.391,392,393,394: New noise blanker and filters
From the CHANGE_LOG file:v1.392,393 May 28, 2020 Noise blankers and filters: Added the Michael Wild noise blanker. Not a lot of operating experience with this yet. It seems not to work on some noise sources compared to the standard blanker. A good test source is 100 kHz Loran-C in AM mode using a UK Kiwi. Increase the gate time (standard blanker) or impulse samples (Wild blanker) to account for the longer Loran-C pulses compared to the usual impulse noise. Fixed wdsp filter: the control sliders had no effect previously! Now it works quite well. You have to adjust the gain carefully to prevent overload. Added test pulse gain and pulse width controls. And also whether the pulse is applied before or after the passband filtering. The Wild blanker seems only effective on post-filter pulses. Probably because the filter is turning the pre-filter step function pulses into nicer band-limited pulses. -
From the CHANGE_LOG file:v1.391 May 23, 2020 User interface changes: SAL, SAU mode passband image will only show single sideband (just like LSB, USB). Ctrl/alt-click on mode button toggles modes backwards (most useful with SAM modes). Same works with keyboard shortcuts, e.g. ctrl/alt-A toggles SAM modes backwards. Noise blankers and filters: Reworked the audio tab user interface to support multiple blanker/filter algorithms. New algorithms planned but not yet available are greyed-out in the menus. From Warren Pratt's wdsp package added the variable-leak LMS algorithm. Merged Howard Su's RPi changes. Note: RPi is not officially supported by KiwiSDR. Ask for help on the KiwiSDR forum: http://forum.kiwisdr.com/discussion/1986/port-kiwisdr-to-raspberrypi-3b Bug fixes: Audio recordings made in SAS (synchronous AM stereo) mode now work. Fixed problem with ITU region 2 Kiwis and shift-clicking waterfall in 75/80m band segment. from lazywalker: fixed problems with frequency memory and reload value when transverter offset used. -
