36,753
670
  • v1.391,392,393,394: New noise blanker and filters
    From the CHANGE_LOG file:
    v1.394  May 31, 2020
        Noise blankers and filters:
            Added the spectral noise reduction filter by Frank, DD4WH and Michael, DL2FW, via the
            Teensy-ConvolutionSDR and UHSDR projects. See: github.com/df8oe/UHSDR/wiki/Noise-reduction
            This noise filter works really, really well. Especially for voice signals.
            A good alternative to the LMS filters.
        Note that the Wild blanker and all the noise filters (wdsp, LMS, spectral) don't currently work
        with the modes: IQ, SAS and DRM (i.e. the 2-channel IQ modes). This will be fixed at some point.
    This filter is on the main control panel, audio tab, "noise > filter" menu. Click the "more" button to the right of the menu to adjust the filter parameters, although the filter works well with the defaults. In some cases you might have to increase the filter gain to match the filter-off level, especially during A/B comparisons. Try it with a weak station on the AM broadcast band or ham band SSB signal.
    Note that some noise filters always require their sections be enabled via the "more" panel. Otherwise simply selecting their menu entry does nothing. In particular the wdsp and LMS filters since they have independent denoiser and autonotch sections that are enabled separately (or both simultaneously).
    PowernumptybensoncathalferrisLX1DQHB9TMC
    v1.394  May 31, 2020
    v1.394  May 31, 2020
    v1.392,393  May 28, 2020
            Added the Michael Wild noise blanker. Not a lot of operating experience with this yet.
                It seems not to work on some noise sources compared to the standard blanker.
                A good test source is 100 kHz Loran-C in AM mode using a UK Kiwi.
                Increase the gate time (standard blanker) or impulse samples (Wild blanker) to
                account for the longer Loran-C pulses compared to the usual impulse noise.
            Fixed wdsp filter: the control sliders had no effect previously!
                Now it works quite well. You have to adjust the gain carefully to prevent overload.
            Added test pulse gain and pulse width controls. And also whether the pulse is
                applied before or after the passband filtering. The Wild blanker seems only
                effective on post-filter pulses. Probably because the filter is turning the
                pre-filter step function pulses into nicer band-limited pulses.
    bensoncathalferrisHB9TMC
