36,745
670
  • Obtaining date/time from the Kiwi's GPS [fixed in v1.417]
    v1.417  October 30, 2020
        Allow GPS to set date/time. See admin page, GPS tab, new setting on top bar.
            Defaults to false.
            Before this can happen the GPS-to-UTC correction must be received from the GPS
            navigation message stream. This can take from zero to 12.5 minutes depending on
            the sat page/subframe transmission phase. The date correction has been tested
            using navigation data streams from Navstar, QZSS and Galileo.
            Only one date correction is performed per restart. However the previous constant
            correction of the system time (but not date) whenever it differs more than
            2 seconds from GPS time is still in effect.
        Added FAX extension frequencies for CN stations XSQ and an UNID per forum user Fabrys.
    So in the log you might see something like this which shows a date/time update via PRN-N02 (Navstar) from Oct 25 00:01:40 to Oct 30 04:56:07
    Sun Oct 25 00:01:38 00:01:33.488 ....        GPS/UTC +18 sec
    Sun Oct 25 00:01:40 00:01:35.080 ....      L GPS correcting date: PRN-N02  weeks=2129(81+1024*2) weekSec=449767.5
    Sun Oct 25 00:01:40 00:01:35.081 ....      L GPS correcting date: gps    Fri Oct 30 04:56:07 2020 UTC
    Sun Oct 25 00:01:40 00:01:35.081 ....      L GPS correcting date: system Sun Oct 25 00:01:40 2020 UTC
    Fri Oct 30 04:56:07 00:01:35.089 ....      L GPS correcting date: date/time UPDATED
    UR5VIB
  • v1.415 release
    v1.415  October 20, 2020
        Admin network tab: added Ethernet MTU selection option of 1440 (default 1500) which
            seems to help some installations using 4G Internet connections.
        Bug fixes:
            Well-known DNS server 1.1.1.1 is always added to end of /etc/resolv.conf file.
            "Photo max height" field can no longer be set blank (which prevented page load).
    rz3dvpcathalferrisWA2ZKDPowernumptyLX1DQ
  • v1.415 release
        Bug fixes:
  • v1.415 release
        Bug fixes:
  • v1.415 release
        Bug fixes:
