36,744
670
  • v1.419,423: added non-NBFM squelch
    v1.419  November 8, 2020
        Added a simple RSSI-based squelch for the non-NBFM modes.
            See audio tab of control panel. Based on Christoph's squelch from kiwirecorder.
    Don't expect too much from this squelch implementation. It's not a VAD or anything. On the audio tab move the squelch slider fully left to disable (default). Two squelch values are stored separately: one for NBFM and another for all other modes (except DRM which doesn't need it).
    For the non-NBFM squelch the slider represents dB above the median of a number of past RSSI (S-meter) values. There is also a menu of "tail" times -- additional time the squelch is held open before being closed.
    The speaker icon now has a third color, white, indicating the squelch is closed (hence no audio). This in addition to red (muted) and green (squelch open or disabled).
    Powernumptydl7awlWA2ZKDbensonCommSigmaChrisSmolinskinjccathalferris
  • User login to bypass time limits
    It will ask after the timeout occurs. This is a problem for people making recordings that don't want the interruption. In that case you can give it in the URL: password=... or pwd=... e.g. the_kiwi:8073/?pwd=...
    See the documentation: http://kiwisdr.com/quickstart/index.html#id-user-tune
    ChrisSmolinski
