36,744
670
  • New KiwiSDR forum: differences and features
    Welcome to the new KiwiSDR forum, hosted on kiwisdr.com and running the latest Vanilla 3.3 forum software.
    All of the forum content from valentfx.com was copied over including attachments, avatars, inboxes etc.
    The most problematic issue will be external links from other places pointing to specific forum posts. Forum links were previously of the form valentfx.com/vanilla/discussion/... and need to be changed to the form forum.kiwisdr.com/discussion/... This is of course impossible for immutable (non-editable) content like links embedded in Twitter tweets. It was not possible to automatically redirect references from the Valent forum for various reasons. So if you have editable links into the old forum please update them. However, links to old posts on Valent will continue to work as long as Valent hosts the old KiwiSDR content.
    Also, the time to edit your posts is not limited on this forum (previously the limit was one day). So if your post contains a link back to Valent you can simply edit it to correct the link per the above. In theory this shouldn't be necessary as the database was scrubbed very carefully to update all the links.
    The forum has a slightly different look but basically the same features. The biggest change is editing posts. There is no longer a "preview" button. When using the new paragraph icon on the left margin, and also when double-clicking on words and making text selections, the formatting changes are immediate. It is a "what you see is what you get" (WYSIWYG) interface. Experiment and you'll see how it works.
    The search box is at top right. Use the "Mark All Viewed" button on the top bar as all the previous viewed information has been reset.
    If you are having any problems (e.g. can't login, can't post, getting error messages, etc.) please email support@kiwisdr.com
    ChristophJimo
  • v1.419,423: added non-NBFM squelch
    v1.419  November 8, 2020
        Added a simple RSSI-based squelch for the non-NBFM modes.
            See audio tab of control panel. Based on Christoph's squelch from kiwirecorder.
    Don't expect too much from this squelch implementation. It's not a VAD or anything. On the audio tab move the squelch slider fully left to disable (default). Two squelch values are stored separately: one for NBFM and another for all other modes (except DRM which doesn't need it).
    For the non-NBFM squelch the slider represents dB above the median of a number of past RSSI (S-meter) values. There is also a menu of "tail" times -- additional time the squelch is held open before being closed.
    The speaker icon now has a third color, white, indicating the squelch is closed (hence no audio). This in addition to red (muted) and green (squelch open or disabled).
    Powernumptydl7awlWA2ZKDbensonCommSigmaChrisSmolinskinjccathalferris
