36,234
639
  • Possible TDoA problem when using KiWi's in 3 CH mode [fixed in v1.255]
    v1.258 is out with TDoA UI and reliability improvements:
    v1.257, 258  January 9, 2019
        TDoA UI improvements:
            Added "4" button to zoom buttons at upper left. Zooms directly to level 4.
            Shift-clicking on the +/- buttons zooms by 3 levels instead of just one.
            Added distance scale (in km/m & miles/feet) to map at lower right.
            Added ruler function. Click on the "protractor" icon at lower right. Mouse cursor will
                change to cross symbol. Click on starting map position. Move mouse to ending map
                position and double-click to end ruler measurement. Or single-click to make
                intermediate measurement and continue. Click on icon to clear measurement.
                Don't use escape key as that will close the extension! (this may be fixed in the future)
        Admin GPS tab: now says "loading maps..." when display delayed due to map download process.
        By request: URL parameter "no_geo" to disable browser from determining and sending Kiwi the
            geolocation information of the connecting user.
            Use like other URL parameters, e.g. "mykiwi:8073/?f=5Mam&mute&no_geo"
            This will someday become one of the "user preferences" options.
  • Grove Project
    Not sure what's wrong there. One of my browsers shows the pdf in that thread fine and the other doesn't. Here it is again:
    Christoph has identified the issues necessary to make 20 kHz Kiwis work with TDoA (in principle at least). One issue was implemented in v1.252/253. Others to follow as time permits.
  • GPS Question
  • 10ch receiver mode ?
    Absolutely impossible. Because I've run out of cute little icon critters to add to the admin mode page.
    But seriously, I'll look into it..
    WA2ZKDPowernumpty
