36,263
640
  • Galileo down [alert flag added in v1.302]
    All right, v1.304 has individual enabling of Navstar/QZSS/Galileo acquisition.
    PowernumptyHB9TMC
    v1.303 is out with a new switch "Include Galileo?". Also fixed a bug where "Include alerted?" didn't have immediate effect each time you changed it. Also fixes-per-minute is shown as "f/min" at the bottom of the page.
    Now I've seen cases where including non-alerting Galileo sats will change solutions ("S") from green to red reliably. So that seems to be an indication that not all sats capable of causing problems are marked alerted. But I've also seen plenty of cases where Galileo sats are providing perfectly fine solutions too.
    HB9TMC
    Since last Thursday/Friday:
    NOTICE ADVISORY TO GALILEO USERS (NAGU) 2019026
    DATE GENERATED (UTC): 2019-07-13 20:15
    NAGU TYPE: GENERAL
    NAGU NUMBER: 2019026
    NAGU SUBJECT: SERVICE OUTAGE
    NAGU REFERENCED TO: 2019025
    START DATE EVENT (UTC): 2019-07-12 01:50
    END DATE EVENT (UTC): N/A
    SATELLITE AFFECTED: ALL
    EVENT DESCRIPTION: UNTIL FURTHER NOTICE, USERS EXPERIENCE A SERVICE OUTAGE. THE SIGNALS ARE NOT TO BE USED.
    https://www.gpsworld.com/galileo-down-over-weekend
    This may have implications for the Kiwi as the Galileo code does not currently recognize a sat being in an "alarm" state preventing its use in position/timing solutions. For example the alarm state of QZSS sats is correctly detected and an option exists on the GPS tab of the admin page to include alarmed sats or not (Q195 is in alarm as of this writing).
    The Galileo code does look for alert pages in the I/NAV messages (page type = 1). But none of these are currently seen. We are looking more closely at the Galileo ICD to see what other bits might be present the code should be checking.
    Below is an image where the position solutions differ substantially when Galileo is included in the pool of sats (red markers) versus not (green markers). The green markers are close to the true position.
    PowernumptyHB9TMC
    NAGU TYPE: GENERAL
    PowernumptyHB9TMC
