 - jks
 - 36,270
 - 642
Update Problem [fixed in v1.332]
This feature has not been tested with IPv6 or mixed IPv4/IPv6 local networks. So there is likely some debugging required. -
Locked out by using the Admin page?
The only way you will get the "Sorry, this KiwiSDR server is being used for development right now" message is if on the "control" tab of the admin page you have set the "enable user connections?" switch to "no" AND you have left the "reason if disabled" field blank. Set the switch back to "yes" and you should be fine (no restart is required).
Above, the "ku" ("kiwi up") command was mentioned. But I think everyone meant to say "up" ("update") which is the command to manually update the software and rebuild from scratch. This is essentially the manual version of what the automatic software update does. See the link in Stu's post.
The "up" command cannot be used from the console tab of the admin page. That's why you get the error message (there is a different procedure needed in this case). The "cdp" "up" command sequence can only ever be used from a root ssh/PuTTY login to the Beagle. But that is not the solution that is needed here. -
S meter extension - prevent clearing? [fixed in v1.318]
v1.318 August 27, 2019 FAX extension: Add LPM (lines per minute) selection. Automatically set 60 LPM for JJC/JSC Frequency list corrections; added XSG Shanghai; removed BMF Taipei S-meter extension: Don't clear graph on frequency change. Instead draw vertical division marker: red when frequency change, green when mode change. Better detection of missing audio panner API on some browsers.
